Discovery Oracle Tablespace - Error Item prototype - "proxy <tbs> does not exist"
  • Tad C
    • Oct 2019
    I need help about Discovery of Oracle Tablespaces.
    Fisrt, I'm using Zabbix 4 on Linux.
    I'm using the below link to Discovery Oracle tablespaces with ODBC:
    https://www.zabbix.com/documentation...ry/sql_queries
    I've created a Discovery Rule:
    Type: Database Monitor
    Key: db.odbc.discovery[ora_tablespace_used_pct_v2, {$DSN}]
    SQL Query:
    select tbs.tablespace_name as tablespace_name, tbs.used_pct as used_pct
    from (select /*+ RULE */a.tablespace_name, round((((a.size_gb - f.size_gb)/a.size_gb) * 100), 2) used_pct from
    (SELECT TABLESPACE_NAME, SUM(BYTES)/1024/1024/1024 SIZE_GB FROM DBA_DATA_FILES GROUP BY TABLESPACE_NAME) a,
    (SELECT TABLESPACE_NAME, SUM(BYTES)/1024/1024/1024 SIZE_GB FROM DBA_FREE_SPACE GROUP BY TABLESPACE_NAME) f
    where a.tablespace_name = f.tablespace_name
    and a.tablespace_name in (select tablespace_name from dba_tablespaces where contents <> 'UNDO')) tbs
    union
    select tablespace_name, round(((tablespace_size - free_space)/tablespace_size) * 100, 2)
    from dba_temp_free_space
    The item prototype:
    Name: Tablespace: {#TABLESPACE_NAME} - Used PCT
    Type: Zabbix internal
    key: zabbix[proxy,{#TABLESPACE_NAME},lastaccess]
    For a host, Zabbix returns the list of tablespaces, but for each tablespace show me a error:
    Proxy "SYSAUX" does not exist.
    Where SYSAUX is the name of a tablespace.
    Please, can you help me to solve this problem?
    **** What is the correct way to use Item prototype for this case? ****
    Do I must use database monitor in item prototype?
    I did another way, but I dont know if this is the best way:
    SQL Query in Item prototype:
    select used_pct from
    (select tbs.tablespace_name as tablespace_name, tbs.used_pct as used_pct
    union
    from dba_temp_free_space)
    where tablespace_name = '{#TABLESPACE_NAME}'
    Thank you very much!
