Hello everyone,
After restarting the Zabbix server (unplanned). For several days I got an error message on the zabbix user interface. Do you have any idea how to solve this problem?
Please see screenshot !
Thank you !
This is the error message:
Thank you !
- session_start(): open(/var/lib/php/sessions/sess_oj700tkhgfdeoopvtbfki56h07, O_RDWR) failed: Read-only file system (30) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CControllerWidgetSystemView->__construct() → CController->__construct() → CSession::start() → session_start() in include/classes/core/CSession.php:49]
- session_write_close(): open(/var/lib/php/sessions/sess_oj700tkhgfdeoopvtbfki56h07, O_RDWR) failed: Read-only file system (30) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CControllerWidgetSystemView->__construct() → CController->__construct() → CSession::start() → session_write_close() in include/classes/core/CSession.php:53]
- session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/sessions) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CControllerWidgetSystemView->__construct() → CController->__construct() → CSession::start() → session_write_close() in include/classes/core/CSession.php:53]
- session_start(): open(/var/lib/php/sessions/sess_oj700tkhgfdeoopvtbfki56h07, O_RDWR) failed: Read-only file system (30) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidget->checkInput() → CController->validateInput() → CSession::keyExists() → CSession:
pen() → session_start() in include/classes/core/CSession.php:138] - session_write_close(): open(/var/lib/php/sessions/sess_oj700tkhgfdeoopvtbfki56h07, O_RDWR) failed: Read-only file system (30) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidget->checkInput() → CController->validateInput() → CSession::keyExists() → CSession::close() → session_write_close() in include/classes/core/CSession.php:149]
- session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/sessions) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidget->checkInput() → CController->validateInput() → CSession::keyExists() → CSession::close() → session_write_close() in include/classes/core/CSession.php:149]
