I installed Zabbix 2.2 on FreeBSD 10.0 RELEASE x64.
It was running fine until I enabled email. After the server sent one email using a Trigger and Action I created it some how managed to segfault and now I'm unable to start it again....? I've also done a full update too of installed packages/libraries.
Here is the output from the log:
Would anyone be able to offer any assistance?
Actually things were just getting juicy as I had just configured the ZAX/Pubnub alerting system, though it didn't work.
Really hoping that I can get this back up and running again as in the few days I had it running it was really good, though learning curve for creating events etc... might have been a bit steepish but all good fun
Thanks.
3286:20140917:230404.186 server #35 started [history syncer #6] 3222:20140917:230404.189 server #0 started [main process] 3296:20140917:230404.191 server #39 started [proxy poller #1] 3299:20140917:230404.192 server #40 started [self-monitoring #1] 3289:20140917:230404.194 server #37 started [history syncer #8] 3279:20140917:230404.195 server #29 started [discoverer #1] 3279:20140917:230404.225 cannot link template: template with item key "sysName" already linked to the host 3279:20140917:230404.230 cannot link template: template with item key "sysName" already linked to the host 3267:20140917:230404.297 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x40]. Crashing ... 3267:20140917:230404.297 ====== Fatal information: ====== 3267:20140917:230404.297 program counter not available for this architecture 3267:20140917:230404.297 === Registers: === 3267:20140917:230404.297 register dump not available for this architecture 3267:20140917:230404.297 === Backtrace: === 3267:20140917:230404.297 1: 0x45549b <print_fatal_info+0x7b> at /usr/local/sbin/zabbix_server 3267:20140917:230404.297 0: 0x4558fc <zbx_set_common_signal_handlers+0x2fc> at /usr/local/sbin/zabbix_server 3267:20140917:230404.297 === Memory map: === 3267:20140917:230404.297 memory map not available for this platform 3267:20140917:230404.297 ================================ 3222:20140917:230404.298 One child process died (PID:3267,exitcode/signal:65280). Exiting ... 3222:20140917:230406.323 syncing history data... 3222:20140917:230406.323 syncing history data done 3222:20140917:230406.323 syncing trends data... 3222:20140917:230406.323 syncing trends data done 3222:20140917:230406.323 Zabbix Server stopped. Zabbix 2.2.5 (revision 47411).
Thanks.
