Hello guys,
I`ve installed the last version of Zabbix Server and Agent also (zabbix_agentd (daemon) (Zabbix) 4.4.1)
I`ve problem with MariaDB server monitoring , I`ve googl too much before post here but what I see there is just old configuration
but my userparameter_mysql.conf looks like this
Problem is that I`ve created .my.cnf in mostly every root /etc/zabbix , /usr/share/zabbix , etc and it doesn`t work
In that configurtaion there`s written
there`s not /var/lib/zabbix directory on my CentOS (CentOS Linux release 7.7.1908 (Core)) system .
could you please help me to understand what I do wrong and how may I solve that problem ?
# For all the following commands HOME should be set to the directory that has .my.cnf file with password information.
# Flexible parameter to grab global variables. On the frontend side, use keys like mysql.status[Com_insert].
# Key syntax is mysql.status[variable].
UserParameter=mysql.status[*],echo "show global status where Variable_name='$1';" | HOME=/etc/zabbix mysql -N | awk '{print $$2}' # My line
# Flexible parameter to determine database or table size. On the frontend side, use keys like mysql.size[zabbix,history,data].
# Key syntax is mysql.size[<database>,<table>,<type>].
# Database may be a database name or "all". Default is "all".
# Table may be a table name or "all". Default is "all".
# Type may be "data", "index", "free" or "both". Both is a sum of data and index. Default is "both".
# Database is mandatory if a table is specified. Type may be specified always.
# Returns value in bytes.
# 'sum' on data_length or index_length alone needed when we are getting this information for whole database instead of a single table
UserParameter=mysql.size[*],echo "select sum($(case "$3" in both|"") echo "data_length+index_length";; data|index) echo "$3_length";; free) echo "data_free";; esac)) from information_schema.tables$([[$
#Default below
UserParameter=mysql.ping,HOME=/etc/zabbix mysqladmin ping | grep -c alive
#My line
UserParameter=mysql.uptime,HOME=/etc/zabbix mysqladmin status | cut -f2 -d ":" | cut -f1 -d "T" | tr -d " "
UserParameter=mysql.threads,HOME=/etc/zabbix mysqladmin status | cut -f3 -d ":" | cut -f1 -d "Q" | tr -d " "
UserParameter=mysql.questions,HOME=/etc/zabbix mysqladmin status | cut -f4 -d ":"|cut -f1 -d "S" | tr -d " "
UserParameter=mysql.slowqueries,HOME=/etc/zabbix mysqladmin status | cut -f5 -d ":" | cut -f1 -d "O" | tr -d " "
UserParameter=mysql.qps,HOME=/etc/zabbix mysqladmin status | cut -f9 -d ":" | tr -d " "
UserParameter=mysql.version,mysql -V
#template_db_mysql.conf created by Zabbix for "Template DB MySQL" and Zabbix 4.2 #For OS Linux: You need create .my.cnf in zabbix-agent home directory (/var/lib/zabbix by default) #For OS Windows: You need add PATH to mysql and mysqladmin and create my.cnf in %WINDIR%\my.cnf,C:\my.cnf,BASEDIR\my.cnf https://dev.mysql.com/doc/refman/5.7/en/option-files.html #The file must have three strings: #[mysqld] #user=zbx_monitor #password=<password> # UserParameter=mysql.ping[*], mysqladmin -h"$1" -P"$2" ping UserParameter=mysql.get_status_variables[*], mysql -h"$1" -P"$2" -sNX -e "show global status" UserParameter=mysql.version[*], mysqladmin -s -h"$1" -P"$2" version UserParameter=mysql.db.discovery[*], mysql -h"$1" -P"$2" -sN -e "show databases" UserParameter=mysql.dbsize[*], mysql -h"$1" -P"$2" -sN -e "SELECT SUM(DATA_LENGTH + INDEX_LENGTH) FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA='$3'" UserParameter=mysql.replication.discovery[*], mysql -h"$1" -P"$2" -sNX -e "show slave status" UserParameter=mysql.slave_status[*], mysql -h"$1" -P"$2" -sNX -e "show slave status"
Is it Correct?
