Hello all!
I'm trying to discover all Virtual Directors on a EMC VPLEX but the discovery rule fails when I try to obtain the SNMPINDEX with a SNMP "error: (genError) A general failure occured" message.
The OID is correct because I try on the console but (always a but...) at the end of the snmpwalk I can see the same message that I found on the Zabbix frontend:
Error in packet.
Reason: (genError) A general failure occured
Failed object: SNMPv2-SMI::enterprises.1139..........
If I make a snmpget of the failed object it's ok and no error appears.
As I read on google (a lot of forum posts) there's a workarround changing the snmpd.conf adding this two lines to increase the timeout of the daemon:
agentXTimeout 60
agentXRetries 10
But it doesn't resolve the problem.
My server is 2.0.4
Any ideas?
Thanks in advance!
Error in packet.
agentXTimeout 60
agentXRetries 10
My server is 2.0.4
Any ideas?
Thanks in advance!
