Apologies for those that may see this as a duplicate, but I think this is the better place for this, rather than Zabbix Help.
I am trying to find examples of a keyword in a logfile - namely the word "ERROR".
My system uses logfile rotation, so I have created the following regular expression:
Which works fine, and when I go into Administration > Regular Expressions and test it against the following filename, it works correctly:
However, I am unable to retrieve data using the following Item Key:
I have the item defined as an Active check, other Active checks work on this host, I have the Information Type set to Log, and a Log time format of: dd/MM/yyyy hh:mm:ss
The content of the logfile begins with the following:
I also have a new Application of "Logfile", but when I go to Latest Data I don't see the Application as it hasn't sent any data to the server?
Kind Regards,
Morrolan
[0-9]+_UFC.ListProcessor.exe_[0-9]{1,4}_[0-9].log
20140919_UFC.ListProcessor.exe_7984_5.log
logrt["C:\UFC\log\[0-9]+_UFC.ListProcessor.exe_[0-9]{1,4}_[0-9].log","ERROR"]
19/09/2014 03:05:16.323 ERROR: Converting a message from transmission format:
Kind Regards,
Morrolan
