Timestamp Removal
  • marcas
    • Jun 2019
    Timestamp Removal
    I am currently relaying metrics through a Zabbix agent via HTML. I wanted to know if there is a way I can remove the timestamp that is sent while displaying in plain text? Is there a configure file or something within Zabbax UI that I can change to not display that column?
    After doing a deeper dive is there a way I can remove the timestamp via preprocessing of the function from that particular host?
    Thanks in advance!
