Active Checks from dmz to LAN not working
  • rolfrolf
    • Oct 2019
    • 17
    Hey Guys hope anyone can help me.
    i got a Zabbix Proxy in our DMZ so it is available for our costumers and the server is not reachable from the Internet.
    Now the passive checks are working perfect but the active checks always say: active check configuration recieved from ... ZBX_TCP_READ() timed out
    when i put the proxy in our lan the active checks are also working perfectly.
    i tried telnet from the proxy to the agents and from the opposite side and everything is reachable.
    hope anyone has an idea on what i could try.
    thanks in advance
  • Hamardaban
    • May 2019
    • 2714
    Carefully consider the full scheme of interaction agent<->proxy<->server in case of active and passive checks. Note that when active checks first a check list request from agent to proxy to port 10051
    • AvaTTaR
      • Dec 2018
      • 96
      Some problem with firewall configuration test connection from proxy to server via telnet on port 10051, I have same scheme on DMZ and it works perfectly.
      • rolfrolf
        rolfrolf commented
        tested everything and everything works fine
        but i still get this error
        could you maybe send me your conf files? maybe im missing something
    • Nguyen Trang
      • Nov 2019
      If your network has no problem, maybe your timeout too little. Try increasing the value of Timeout in the configuration file on the client. eg: Timeout=25
      • rolfrolf
        rolfrolf commented
        have already tried that and nothing has changed
      • Nguyen Trang
        Nguyen Trang commented
        I had the same problem. A passive check is Ok, but the Active check is not working.
        You can try my configuration (disabled firewall and SELinux) -> restart service
        Server:
        ListenPort=10051
        LogType=file
        LogFile=/var/log/zabbix/zabbix_server.log
        LogFileSize=1
        DebugLevel=3
        PidFile=/var/run/zabbix/zabbix_server.pid
        SocketDir=/var/run/zabbix
        DBHost=localhost
        DBName=zabbix
        DBUser=zabbix
        DBPassword=**
        StartPollers=5
        StartPollersUnreachable=1
        StartTrappers=5
        StartPingers=1
        StartDiscoverers=1
        StartHTTPPollers=1
        StartSNMPTrapper=1
        ListenIP=0.0.0.0
        Timeout=4
        AlertScriptsPath=/usr/lib/zabbix/alertscripts
        ExternalScripts=/usr/lib/zabbix/externalscripts
        LogSlowQueries=3000
        StatsAllowedIP=0.0.0.0/0
        Agent:
        PidFile=/var/run/zabbix/zabbix_agentd.pid
        LogType=file
        LogFile=/var/log/zabbix/zabbix_agentd.log
        LogFileSize=0
        EnableRemoteCommands=1
        Server=::/0
        ServerActive=192.168.40.128
        Hostname=kvm31
        Timeout=30
        Include=/etc/zabbix/zabbix_agentd.d/*.conf
        => Check service
        [root@zabbix-server ~]# systemctl status firewalld
        Active: inactive (dead)
        [root@zabbix-server ~]# sestatus
        SELinux status: disabled
        [root@zabbix-server ~]# netstat -taun | grep 10051
        tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN
