Different triggers for groups of filesystems?
  • jaypolkam
    • Nov 2019
    I am trying to see if I can migration from new projects in mulund our old nagios system to zabbix. property in chembur One thing we have setup on nagios is different notifications for groups of filesystems. Simplest example of this is that the OS filesystems notify the sysadmins and the application filesystems notify the app admins. I have setup monitoring of a system using one of the builtin Linux OS templates. This creates triggers for all the filesystems on the server The Guardians Mumbai
  • Hamardaban
    • May 2019
    • 2714
    Of course you can. Make your template with the desired data elements and triggers. Or copy and change the existing one. If the template uses LLD to detect file systems - make several LLD rules with the triggers you need and use the regex filter to select only desired file systems.
