Setting serverity on host level instead of trigger-level
  • MartOn
    • Aug 2006
    I do not have permission (security reasons) to install agent on servers I'm monitoring. I just use simple ping check and port access testing.
    I have then just created a Ping check Trigger like this:
    {ICMP_Ping:icmpping.max(90)}<1
    I then assign all my hosts to this ICMP_Ping item.
    My problem is that not all of my hosts have the same severity. Some I do not want to generate more than a warning and others are more severe.
    Is there any easy way of doing this or do I have to create duplicate triggers and items?
    (Not easy to duplicate when zabbix do not have a copy button )
    Other examples of monitoring windows servers with no agent install is appreciated.
    /MartOn
  • MartOn
    • Aug 2006
    Is this impossible, since I got no replies?
