ZBX Agent with RHEL[67] and SELinux
  • Ben B
    • Aug 2012
    Folks,
    I've been playing around with getting Zabbix going for an environment, and it seems that with the base policies shipping with RHEL at present kill a lot of functionality from the Zabbix Agent when running in enforcing mode.
    $ sestatus
    SELinux status: enabled
    SELinuxfs mount: /selinux
    Current mode: enforcing
    Mode from config file: enforcing
    Policy version: 24
    Policy from config file: targeted
    > from /var/log/audit.log
    type=AVC msg=audit(1411624838.720:189661): avc: denied { getattr } for pid=1600 comm="zabbix_agentd" path="/proc/1568/cmdline" dev=proc ino=17063 scontext=system_u:system_r:zabbix_agent_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=file
    Anyone out there playing the same game and got it all sorted out? Making it work isn't such a problem, its just making another bespoke customisation that needs to be retained forevermore.
    Auto-discovery doesn't work, along with a few other things
    Thanks.
  • ingus.vilnis
    • Mar 2014
    • 908
    I am really not an expert in SELinux but I usually sort my connection issues with this simple line.
    setsebool -P zabbix_can_network=true
    However not sure if that will solve your issue. These customizations are needed to get it work and I don't know any existing workarounds how to fix it on large scale.
    Best Regards,
    Ingus
