Zabbix Agent 4.4.2 Segmentation Fault on CentOS 7
  • ikogan
    • Nov 2019
    I just upgraded my Agent to 4.4.2-1 on CentOS 7 I'm getting the following dump (downgrading to 4.4.1-1 works fine):
      5759:20191127:000515.582 Starting Zabbix Agent [vpn.gaea.mythicnet.org]. Zabbix 4.4.2 (revision 6d7579cc01).
      5759:20191127:000515.582 **** Enabled features ****
      5759:20191127:000515.582 IPv6 support:          YES
      5759:20191127:000515.582 TLS support:           YES
      5759:20191127:000515.582 **************************
      5759:20191127:000515.582 using configuration file: /etc/zabbix/zabbix_agentd.conf
      5759:20191127:000515.582 agent #0 started [main process]
      5760:20191127:000515.583 agent #1 started [collector]
      5762:20191127:000515.583 agent #3 started[listener #2]
      5761:20191127:000515.583 agent #2 started[listener #1]
      5763:20191127:000515.585 agent #4 started[listener #3]
      5764:20191127:000515.585 agent #5 started [active checks #1]
      5764:20191127:000520.432 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x30]. Crashing ...
      5764:20191127:000520.432 ====== Fatal information: ======
      5764:20191127:000520.432 Program counter: 0x7f3791b2bdf8
      5764:20191127:000520.432 === Registers: ===
      5764:20191127:000520.432 r8      =     7ffeba2bb7b0 =      140732021847984 =      140732021847984
      5764:20191127:000520.432 r9      =              204 =                  516 =                  516
      5764:20191127:000520.432 r10     =         a3f5be37 =           2750791223 =           2750791223
      5764:20191127:000520.432 r11     =     7f3791b629d0 =      139876644563408 =      139876644563408
      5764:20191127:000520.432 r12     =     7ffeba2bb7b0 =      140732021847984 =      140732021847984
      5764:20191127:000520.432 r13     =     7ffeba2bba1c =      140732021848604 =      140732021848604
      5764:20191127:000520.432 r14     =     557e14573df0 =       93999995502064 =       93999995502064
      5764:20191127:000520.432 r15     =                0 =                    0 =                    0
      5764:20191127:000520.432 rdi     =     7ffeba2bb7b0 =      140732021847984 =      140732021847984
      5764:20191127:000520.432 rsi     =                0 =                    0 =                    0
      5764:20191127:000520.432 rbp     =     7ffeba2bb4f0 =      140732021847280 =      140732021847280
      5764:20191127:000520.432 rbx     =     557e14585f74 =       93999995576180 =       93999995576180
      5764:20191127:000520.432 rdx     =     7f3791b2bdf8 =      139876644339192 =      139876644339192
      5764:20191127:000520.432 rax     =     7ffeba2bb7b0 =      140732021847984 =      140732021847984
      5764:20191127:000520.432 rcx     =                0 =                    0 =                    0
      5764:20191127:000520.432 rsp     =     7ffeba2bb4b8 =      140732021847224 =      140732021847224
      5764:20191127:000520.432 rip     =     7f3791b2bdf8 =      139876644339192 =      139876644339192
      5764:20191127:000520.432 efl     =            10207 =                66055 =                66055
      5764:20191127:000520.432 csgsfs  = d9fd000000000033 = 15707711075338158131 = -2739032998371393485
      5764:20191127:000520.432 err     =                4 =                    4 =                    4
      5764:20191127:000520.432 trapno  =                e =                   14 =                   14
      5764:20191127:000520.432 oldmask =                0 =                    0 =                    0
      5764:20191127:000520.432 cr2     =               30 =                   48 =                   48
      5764:20191127:000520.432 === Backtrace: ===
      5764:20191127:000520.433 18: zabbix_agentd: active checks #1 [idle 1 sec](zbx_backtrace+0x42) [0x557e140277d4]
      5764:20191127:000520.433 17: zabbix_agentd: active checks #1 [idle 1 sec](zbx_log_fatal_info+0x151) [0x557e14027a52]
      5764:20191127:000520.433 16: zabbix_agentd: active checks #1 [idle 1 sec](+0x46dea) [0x557e14027dea]
      5764:20191127:000520.433 15: /lib64/libpthread.so.0(+0xf5f0) [0x7f37934d65f0]
      5764:20191127:000520.433 14: /lib64/libc.so.6(+0x156df8) [0x7f3791b2bdf8]
      5764:20191127:000520.433 13: zabbix_agentd: active checks #1 [idle 1 sec](+0x6a514) [0x557e1404b514]
      5764:20191127:000520.433 12: /lib64/libssl.so.10(ssl3_send_client_key_exchange+0x8c3) [0x7f3793278003]
      5764:20191127:000520.433 11: /lib64/libssl.so.10(ssl3_connect+0x9a0) [0x7f379327b460]
      5764:20191127:000520.433 10: zabbix_agentd: active checks #1 [idle 1 sec](zbx_tls_connect+0x499) [0x557e1404dab7]
      5764:20191127:000520.433 9: zabbix_agentd: active checks #1 [idle 1 sec](+0x48a91) [0x557e14029a91]
      5764:20191127:000520.433 8: zabbix_agentd: active checks #1 [idle 1 sec](zbx_tcp_connect+0x9c) [0x557e14029bd9]
      5764:20191127:000520.433 7: zabbix_agentd: active checks #1 [idle 1 sec](+0x15018) [0x557e13ff6018]
      5764:20191127:000520.433 6: zabbix_agentd: active checks #1 [idle 1 sec](active_checks_thread+0x1d6) [0x557e13ff75aa]
      5764:20191127:000520.433 5: zabbix_agentd: active checks #1 [idle 1 sec](zbx_thread_start+0x37) [0x557e1402585b]
      5764:20191127:000520.433 4: zabbix_agentd: active checks #1 [idle 1 sec](MAIN_ZABBIX_ENTRY+0x57e) [0x557e13ff398d]
      5764:20191127:000520.433 3: zabbix_agentd: active checks #1 [idle 1 sec](daemon_start+0x305) [0x557e14026ea5]
      5764:20191127:000520.433 2: zabbix_agentd: active checks #1 [idle 1 sec](main+0x20c) [0x557e13ff3d74]
      5764:20191127:000520.433 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f37919f7505]
      5764:20191127:000520.433 0: zabbix_agentd: active checks #1 [idle 1 sec](+0x10f29) [0x557e13ff1f29]
      5764:20191127:000520.433 === Memory map: ===
      5764:20191127:000520.433 557e13fe1000-557e1407c000 r-xp 00000000 fd:00 3425                       /usr/sbin/zabbix_agentd
      5764:20191127:000520.433 557e1427c000-557e1427d000 r--p 0009b000 fd:00 3425                       /usr/sbin/zabbix_agentd
      5764:20191127:000520.433 557e1427d000-557e1427f000 rw-p 0009c000 fd:00 3425                       /usr/sbin/zabbix_agentd
      5764:20191127:000520.433 557e1427f000-557e14285000 rw-p 00000000 00:00 0
      5764:20191127:000520.433 557e1454e000-557e1456f000 rw-p 00000000 00:00 0                          [heap]
      5764:20191127:000520.433 557e1456f000-557e145a6000 rw-p 00000000 00:00 0                          [heap]
      5764:20191127:000520.433 7f378db21000-7f378db36000 r-xp 00000000 fd:00 710                        /usr/lib64/libgcc_s-4.8.5-20150702.so.1
      5764:20191127:000520.434 7f378db36000-7f378dd35000 ---p 00015000 fd:00 710                        /usr/lib64/libgcc_s-4.8.5-20150702.so.1
      5764:20191127:000520.434 7f378dd35000-7f378dd36000 r--p 00014000 fd:00 710                        /usr/lib64/libgcc_s-4.8.5-20150702.so.1
      5764:20191127:000520.434 7f378dd36000-7f378dd37000 rw-p 00015000 fd:00 710                        /usr/lib64/libgcc_s-4.8.5-20150702.so.1
      5764:20191127:000520.434 7f378dd37000-7f378dd3d000 r-xp 00000000 fd:00 759                        /usr/lib64/libnss_dns-2.17.so
      5764:20191127:000520.434 7f378dd3d000-7f378df3c000 ---p 00006000 fd:00 759                        /usr/lib64/libnss_dns-2.17.so
      5764:20191127:000520.434 7f378df3c000-7f378df3d000 r--p 00005000 fd:00 759                        /usr/lib64/libnss_dns-2.17.so
      5764:20191127:000520.434 7f378df3d000-7f378df3e000 rw-p 00006000 fd:00 759                        /usr/lib64/libnss_dns-2.17.so
      5764:20191127:000520.434 7f378df3e000-7f378e92b000 r--s 00000000 fd:00 12664217                   /var/lib/sss/mc/initgroups
      5764:20191127:000520.434 7f378e92b000-7f378e933000 r-xp 00000000 fd:00 896324                     /usr/lib64/libnss_sss.so.2
      5764:20191127:000520.434 7f378e933000-7f378eb32000 ---p 00008000 fd:00 896324                     /usr/lib64/libnss_sss.so.2
      5764:20191127:000520.434 7f378eb32000-7f378eb33000 r--p 00007000 fd:00 896324                     /usr/lib64/libnss_sss.so.2
      5764:20191127:000520.434 7f378eb33000-7f378eb34000 rw-p 00008000 fd:00 896324                     /usr/lib64/libnss_sss.so.2
      5764:20191127:000520.434 7f378eb34000-7f378eb40000 r-xp 00000000 fd:00 761                        /usr/lib64/libnss_files-2.17.so
      5764:20191127:000520.434 7f378eb40000-7f378ed3f000 ---p 0000c000 fd:00 761                        /usr/lib64/libnss_files-2.17.so
      5764:20191127:000520.434 7f378ed3f000-7f378ed40000 r--p 0000b000 fd:00 761                        /usr/lib64/libnss_files-2.17.so
      5764:20191127:000520.434 7f378ed40000-7f378ed41000 rw-p 0000c000 fd:00 761                        /usr/lib64/libnss_files-2.17.so
      5764:20191127:000520.434 7f378ed41000-7f378ed47000 rw-p 00000000 00:00 0
      5764:20191127:000520.434 7f378ed47000-7f378ed49000 r-xp 00000000 fd:00 733                        /usr/lib64/libfreebl3.so
      5764:20191127:000520.434 7f378ed49000-7f378ef48000 ---p 00002000 fd:00 733                        /usr/lib64/libfreebl3.so
      5764:20191127:000520.434 7f378ef48000-7f378ef49000 r--p 00001000 fd:00 733                        /usr/lib64/libfreebl3.so
      5764:20191127:000520.434 7f378ef49000-7f378ef4a000 rw-p 00002000 fd:00 733                        /usr/lib64/libfreebl3.so
      5764:20191127:000520.434 7f378ef4a000-7f378ef6e000 r-xp 00000000 fd:00 31649                      /usr/lib64/libselinux.so.1
      5764:20191127:000520.434 7f378ef6e000-7f378f16d000 ---p 00024000 fd:00 31649                      /usr/lib64/libselinux.so.1
      5764:20191127:000520.434 7f378f16d000-7f378f16e000 r--p 00023000 fd:00 31649                      /usr/lib64/libselinux.so.1
      5764:20191127:000520.434 7f378f16e000-7f378f16f000 rw-p 00024000 fd:00 31649                      /usr/lib64/libselinux.so.1
      5764:20191127:000520.434 7f378f16f000-7f378f171000 rw-p 00000000 00:00 0
      5764:20191127:000520.434 7f378f171000-7f378f178000 r-xp 00000000 fd:00 7826                       /usr/lib64/librt-2.17.so
      5764:20191127:000520.434 7f378f178000-7f378f377000 ---p 00007000 fd:00 7826                       /usr/lib64/librt-2.17.so
      5764:20191127:000520.434 7f378f377000-7f378f378000 r--p 00006000 fd:00 7826                       /usr/lib64/librt-2.17.so
      5764:20191127:000520.434 7f378f378000-7f378f379000 rw-p 00007000 fd:00 7826                       /usr/lib64/librt-2.17.so
      5764:20191127:000520.434 7f378f379000-7f378f381000 r-xp 00000000 fd:00 747                        /usr/lib64/libcrypt-2.17.so
      5764:20191127:000520.434 7f378f381000-7f378f580000 ---p 00008000 fd:00 747                        /usr/lib64/libcrypt-2.17.so
      5764:20191127:000520.434 7f378f580000-7f378f581000 r--p 00007000 fd:00 747                        /usr/lib64/libcrypt-2.17.so
      5764:20191127:000520.434 7f378f581000-7f378f582000 rw-p 00008000 fd:00 747                        /usr/lib64/libcrypt-2.17.so
      5764:20191127:000520.434 7f378f582000-7f378f5b0000 rw-p 00000000 00:00 0
      5764:20191127:000520.434 7f378f5b0000-7f378f5b3000 r-xp 00000000 fd:00 31670                      /usr/lib64/libkeyutils.so.1.5
      5764:20191127:000520.434 7f378f5b3000-7f378f7b2000 ---p 00003000 fd:00 31670                      /usr/lib64/libkeyutils.so.1.5
      5764:20191127:000520.434 7f378f7b2000-7f378f7b3000 r--p 00002000 fd:00 31670                      /usr/lib64/libkeyutils.so.1.5
      5764:20191127:000520.434 7f378f7b3000-7f378f7b4000 rw-p 00003000 fd:00 31670                      /usr/lib64/libkeyutils.so.1.5
      5764:20191127:000520.434 7f378f7b4000-7f378f7c2000 r-xp 00000000 fd:00 31633                      /usr/lib64/libkrb5support.so.0.1
      5764:20191127:000520.434 7f378f7c2000-7f378f9c2000 ---p 0000e000 fd:00 31633                      /usr/lib64/libkrb5support.so.0.1
      5764:20191127:000520.434 7f378f9c2000-7f378f9c3000 r--p 0000e000 fd:00 31633                      /usr/lib64/libkrb5support.so.0.1
      5764:20191127:000520.434 7f378f9c3000-7f378f9c4000 rw-p 0000f000 fd:00 31633                      /usr/lib64/libkrb5support.so.0.1
      5764:20191127:000520.434 7f378f9c4000-7f378f9ef000 r-xp 00000000 fd:00 127159                     /usr/lib64/libssh2.so.1.0.1
      5764:20191127:000520.434 7f378f9ef000-7f378fbef000 ---p 0002b000 fd:00 127159                     /usr/lib64/libssh2.so.1.0.1
      5764:20191127:000520.434 7f378fbef000-7f378fbf0000 r--p 0002b000 fd:00 127159                     /usr/lib64/libssh2.so.1.0.1
      5764:20191127:000520.434 7f378fbf0000-7f378fbf1000 rw-p 0002c000 fd:00 127159                     /usr/lib64/libssh2.so.1.0.1
      5764:20191127:000520.434 7f378fbf1000-7f378fc23000 r-xp 00000000 fd:00 70926                      /usr/lib64/libidn.so.11.6.11
      5764:20191127:000520.434 7f378fc23000-7f378fe22000 ---p 00032000 fd:00 70926                      /usr/lib64/libidn.so.11.6.11
      5764:20191127:000520.434 7f378fe22000-7f378fe23000 r--p 00031000 fd:00 70926                      /usr/lib64/libidn.so.11.6.11
      5764:20191127:000520.434 7f378fe23000-7f378fe24000 rw-p 00032000 fd:00 70926                      /usr/lib64/libidn.so.11.6.11
      5764:20191127:000520.434 7f378fe24000-7f378fe5e000 r-xp 00000000 fd:00 717                        /usr/lib64/libnspr4.so
      5764:20191127:000520.434 7f378fe5e000-7f379005d000 ---p 0003a000 fd:00 717                        /usr/lib64/libnspr4.so
      5764:20191127:000520.434 7f379005d000-7f379005e000 r--p 00039000 fd:00 717                        /usr/lib64/libnspr4.so
      5764:20191127:000520.434 7f379005e000-7f3790060000 rw-p 0003a000 fd:00 717                        /usr/lib64/libnspr4.so
      5764:20191127:000520.435 7f3790060000-7f3790062000 rw-p 00000000 00:00 0
      5764:20191127:000520.435 7f3790062000-7f3790066000 r-xp 00000000 fd:00 13726                      /usr/lib64/libplc4.so
      5764:20191127:000520.435 7f3790066000-7f3790265000 ---p 00004000 fd:00 13726                      /usr/lib64/libplc4.so
      5764:20191127:000520.435 7f3790265000-7f3790266000 r--p 00003000 fd:00 13726                      /usr/lib64/libplc4.so
      5764:20191127:000520.435 7f3790266000-7f3790267000 rw-p 00004000 fd:00 13726                      /usr/lib64/libplc4.so
      5764:20191127:000520.435 7f3790267000-7f379026a000 r-xp 00000000 fd:00 13727                      /usr/lib64/libplds4.so
      5764:20191127:000520.435 7f379026a000-7f3790469000 ---p 00003000 fd:00 13727                      /usr/lib64/libplds4.so
     5764:20191127:000520.435 7f3790469000-7f379046a000 r--p 00002000 fd:00 13727                      /usr/lib64/libplds4.so
      5764:20191127:000520.435 7f379046a000-7f379046b000 rw-p 00003000 fd:00 13727                      /usr/lib64/libplds4.so
      5764:20191127:000520.435 7f379046b000-7f3790494000 r-xp 00000000 fd:00 13731                      /usr/lib64/libnssutil3.so
      5764:20191127:000520.435 7f3790494000-7f3790693000 ---p 00029000 fd:00 13731                      /usr/lib64/libnssutil3.so
      5764:20191127:000520.435 7f3790693000-7f379069a000 r--p 00028000 fd:00 13731                      /usr/lib64/libnssutil3.so
      5764:20191127:000520.435 7f379069a000-7f379069b000 rw-p 0002f000 fd:00 13731                      /usr/lib64/libnssutil3.so
      5764:20191127:000520.435 7f379069b000-7f37907c1000 r-xp 00000000 fd:00 433                        /usr/lib64/libnss3.so
      5764:20191127:000520.435 7f37907c1000-7f37909c1000 ---p 00126000 fd:00 433                        /usr/lib64/libnss3.so
      5764:20191127:000520.435 7f37909c1000-7f37909c6000 r--p 00126000 fd:00 433                        /usr/lib64/libnss3.so
      5764:20191127:000520.435 7f37909c6000-7f37909c8000 rw-p 0012b000 fd:00 433                        /usr/lib64/libnss3.so
      5764:20191127:000520.435 7f37909c8000-7f37909ca000 rw-p 00000000 00:00 0
      5764:20191127:000520.435 7f37909ca000-7f37909ef000 r-xp 00000000 fd:00 434                        /usr/lib64/libsmime3.so
      5764:20191127:000520.435 7f37909ef000-7f3790bee000 ---p 00025000 fd:00 434                        /usr/lib64/libsmime3.so
      5764:20191127:000520.435 7f3790bee000-7f3790bf1000 r--p 00024000 fd:00 434                        /usr/lib64/libsmime3.so
      5764:20191127:000520.435 7f3790bf1000-7f3790bf2000 rw-p 00027000 fd:00 434                        /usr/lib64/libsmime3.so
      5764:20191127:000520.435 7f3790bf2000-7f3790c45000 r-xp 00000000 fd:00 435                        /usr/lib64/libssl3.so
      5764:20191127:000520.435 7f3790c45000-7f3790e45000 ---p 00053000 fd:00 435                        /usr/lib64/libssl3.so
      5764:20191127:000520.435 7f3790e45000-7f3790e49000 r--p 00053000 fd:00 435                        /usr/lib64/libssl3.so
      5764:20191127:000520.435 7f3790e49000-7f3790e4a000 rw-p 00057000 fd:00 435                        /usr/lib64/libssl3.so
      5764:20191127:000520.435 7f3790e4a000-7f3790e4b000 rw-p 00000000 00:00 0
      5764:20191127:000520.435 7f3790e4b000-7f3790e67000 r-xp 00000000 fd:00 61145                      /usr/lib64/libsasl2.so.3.0.0
      5764:20191127:000520.435 7f3790e67000-7f3791066000 ---p 0001c000 fd:00 61145                      /usr/lib64/libsasl2.so.3.0.0
      5764:20191127:000520.435 7f3791066000-7f3791067000 r--p 0001b000 fd:00 61145                      /usr/lib64/libsasl2.so.3.0.0
      5764:20191127:000520.435 7f3791067000-7f3791068000 rw-p 0001c000 fd:00 61145                      /usr/lib64/libsasl2.so.3.0.0
      5764:20191127:000520.435 7f3791068000-7f3791099000 r-xp 00000000 fd:00 13764                      /usr/lib64/libk5crypto.so.3.1
      5764:20191127:000520.435 7f3791099000-7f3791298000 ---p 00031000 fd:00 13764                      /usr/lib64/libk5crypto.so.3.1
      5764:20191127:000520.435 7f3791298000-7f379129a000 r--p 00030000 fd:00 13764                      /usr/lib64/libk5crypto.so.3.1
      5764:20191127:000520.435 7f379129a000-7f379129b000 rw-p 00032000 fd:00 13764                      /usr/lib64/libk5crypto.so.3.1
      5764:20191127:000520.435 7f379129b000-7f379129e000 r-xp 00000000 fd:00 13741                      /usr/lib64/libcom_err.so.2.1
      5764:20191127:000520.435 7f379129e000-7f379149d000 ---p 00003000 fd:00 13741                      /usr/lib64/libcom_err.so.2.1
      5764:20191127:000520.435 7f379149d000-7f379149e000 r--p 00002000 fd:00 13741                      /usr/lib64/libcom_err.so.2.1
      5764:20191127:000520.435 7f379149e000-7f379149f000 rw-p 00003000 fd:00 13741                      /usr/lib64/libcom_err.so.2.1
      5764:20191127:000520.435 7f379149f000-7f3791578000 r-xp 00000000 fd:00 31630                      /usr/lib64/libkrb5.so.3.3
      5764:20191127:000520.435 7f3791578000-7f3791777000 ---p 000d9000 fd:00 31630                      /usr/lib64/libkrb5.so.3.3
      5764:20191127:000520.435 7f3791777000-7f3791785000 r--p 000d8000 fd:00 31630                      /usr/lib64/libkrb5.so.3.3
      5764:20191127:000520.435 7f3791785000-7f3791788000 rw-p 000e6000 fd:00 31630                      /usr/lib64/libkrb5.so.3.3
      5764:20191127:000520.435 7f3791788000-7f37917d2000 r-xp 00000000 fd:00 13759                      /usr/lib64/libgssapi_krb5.so.2.2
      5764:20191127:000520.435 7f37917d2000-7f37919d2000 ---p 0004a000 fd:00 13759                      /usr/lib64/libgssapi_krb5.so.2.2
      5764:20191127:000520.435 7f37919d2000-7f37919d3000 r--p 0004a000 fd:00 13759                      /usr/lib64/libgssapi_krb5.so.2.2
      5764:20191127:000520.435 7f37919d3000-7f37919d5000 rw-p 0004b000 fd:00 13759                      /usr/lib64/libgssapi_krb5.so.2.2
      5764:20191127:000520.435 7f37919d5000-7f3791b98000 r-xp 00000000 fd:00 743                        /usr/lib64/libc-2.17.so
      5764:20191127:000520.435 7f3791b98000-7f3791d98000 ---p 001c3000 fd:00 743                        /usr/lib64/libc-2.17.so
      5764:20191127:000520.435 7f3791d98000-7f3791d9c000 r--p 001c3000 fd:00 743                        /usr/lib64/libc-2.17.so
      5764:20191127:000520.435 7f3791d9c000-7f3791d9e000 rw-p 001c7000 fd:00 743                        /usr/lib64/libc-2.17.so
      5764:20191127:000520.435 7f3791d9e000-7f3791da3000 rw-p 00000000 00:00 0
      5764:20191127:000520.435 7f3791da3000-7f3791e03000 r-xp 00000000 fd:00 31639                      /usr/lib64/libpcre.so.1.2.0
      5764:20191127:000520.435 7f3791e03000-7f3792003000 ---p 00060000 fd:00 31639                      /usr/lib64/libpcre.so.1.2.0
      5764:20191127:000520.436 7f3792003000-7f3792004000 r--p 00060000 fd:00 31639                      /usr/lib64/libpcre.so.1.2.0
      5764:20191127:000520.436 7f3792004000-7f3792005000 rw-p 00061000 fd:00 31639                      /usr/lib64/libpcre.so.1.2.0
      5764:20191127:000520.436 7f3792005000-7f379201b000 r-xp 00000000 fd:00 7752                       /usr/lib64/libresolv-2.17.so
      5764:20191127:000520.436 7f379201b000-7f379221a000 ---p 00016000 fd:00 7752                       /usr/lib64/libresolv-2.17.so
      5764:20191127:000520.436 7f379221a000-7f379221b000 r--p 00015000 fd:00 7752                       /usr/lib64/libresolv-2.17.so
      5764:20191127:000520.436 7f379221b000-7f379221c000 rw-p 00016000 fd:00 7752                       /usr/lib64/libresolv-2.17.so
      5764:20191127:000520.436 7f379221c000-7f379221e000 rw-p 00000000 00:00 0
      5764:20191127:000520.436 7f379221e000-7f3792220000 r-xp 00000000 fd:00 749                        /usr/lib64/libdl-2.17.so
      5764:20191127:000520.436 7f3792220000-7f3792420000 ---p 00002000 fd:00 749                        /usr/lib64/libdl-2.17.so
      5764:20191127:000520.436 7f3792420000-7f3792421000 r--p 00002000 fd:00 749                        /usr/lib64/libdl-2.17.so
      5764:20191127:000520.436 7f3792421000-7f3792422000 rw-p 00003000 fd:00 749                        /usr/lib64/libdl-2.17.so
      5764:20191127:000520.436 7f3792422000-7f3792523000 r-xp 00000000 fd:00 751                        /usr/lib64/libm-2.17.so
      5764:20191127:000520.436 7f3792523000-7f3792722000 ---p 00101000 fd:00 751                        /usr/lib64/libm-2.17.so
      5764:20191127:000520.436 7f3792722000-7f3792723000 r--p 00100000 fd:00 751                        /usr/lib64/libm-2.17.so
      5764:20191127:000520.436 7f3792723000-7f3792724000 rw-p 00101000 fd:00 751                        /usr/lib64/libm-2.17.so
      5764:20191127:000520.436 7f3792724000-7f379278a000 r-xp 00000000 fd:00 127162                     /usr/lib64/libcurl.so.4.3.0
      5764:20191127:000520.436 7f379278a000-7f379298a000 ---p 00066000 fd:00 127162                     /usr/lib64/libcurl.so.4.3.0
      5764:20191127:000520.436 7f379298a000-7f379298c000 r--p 00066000 fd:00 127162                     /usr/lib64/libcurl.so.4.3.0
      5764:20191127:000520.436 7f379298c000-7f379298d000 rw-p 00068000 fd:00 127162                     /usr/lib64/libcurl.so.4.3.0
      5764:20191127:000520.436 7f379298d000-7f379298e000 rw-p 00000000 00:00 0
      5764:20191127:000520.436 7f379298e000-7f379299c000 r-xp 00000000 fd:00 127188                     /usr/lib64/liblber-2.4.so.2.10.7
    5764:20191127:000520.436 7f379299c000-7f3792b9b000 ---p 0000e000 fd:00 127188                     /usr/lib64/liblber-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792b9b000-7f3792b9c000 r--p 0000d000 fd:00 127188                     /usr/lib64/liblber-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792b9c000-7f3792b9d000 rw-p 0000e000 fd:00 127188                     /usr/lib64/liblber-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792b9d000-7f3792bef000 r-xp 00000000 fd:00 127190                     /usr/lib64/libldap-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792bef000-7f3792def000 ---p 00052000 fd:00 127190                     /usr/lib64/libldap-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792def000-7f3792df1000 r--p 00052000 fd:00 127190                     /usr/lib64/libldap-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792df1000-7f3792df2000 rw-p 00054000 fd:00 127190                     /usr/lib64/libldap-2.4.so.2.10.7
      5764:20191127:000520.436 7f3792df2000-7f3793028000 r-xp 00000000 fd:00 32919                      /usr/lib64/libcrypto.so.1.0.2k
      5764:20191127:000520.436 7f3793028000-7f3793228000 ---p 00236000 fd:00 32919                      /usr/lib64/libcrypto.so.1.0.2k
      5764:20191127:000520.436 7f3793228000-7f3793244000 r--p 00236000 fd:00 32919                      /usr/lib64/libcrypto.so.1.0.2k
      5764:20191127:000520.436 7f3793244000-7f3793251000 rw-p 00252000 fd:00 32919                      /usr/lib64/libcrypto.so.1.0.2k
      5764:20191127:000520.436 7f3793251000-7f3793255000 rw-p 00000000 00:00 0
      5764:20191127:000520.436 7f3793255000-7f37932bc000 r-xp 00000000 fd:00 32922                      /usr/lib64/libssl.so.1.0.2k
      5764:20191127:000520.436 7f37932bc000-7f37934bc000 ---p 00067000 fd:00 32922                      /usr/lib64/libssl.so.1.0.2k
      5764:20191127:000520.436 7f37934bc000-7f37934c0000 r--p 00067000 fd:00 32922                      /usr/lib64/libssl.so.1.0.2k
      5764:20191127:000520.436 7f37934c0000-7f37934c7000 rw-p 0006b000 fd:00 32922                      /usr/lib64/libssl.so.1.0.2k
      5764:20191127:000520.436 7f37934c7000-7f37934de000 r-xp 00000000 fd:00 7750                       /usr/lib64/libpthread-2.17.so
      5764:20191127:000520.436 7f37934de000-7f37936dd000 ---p 00017000 fd:00 7750                       /usr/lib64/libpthread-2.17.so
      5764:20191127:000520.436 7f37936dd000-7f37936de000 r--p 00016000 fd:00 7750                       /usr/lib64/libpthread-2.17.so
      5764:20191127:000520.436 7f37936de000-7f37936df000 rw-p 00017000 fd:00 7750                       /usr/lib64/libpthread-2.17.so
      5764:20191127:000520.436 7f37936df000-7f37936e3000 rw-p 00000000 00:00 0
      5764:20191127:000520.436 7f37936e3000-7f37936f8000 r-xp 00000000 fd:00 13771                      /usr/lib64/libz.so.1.2.7
      5764:20191127:000520.436 7f37936f8000-7f37938f7000 ---p 00015000 fd:00 13771                      /usr/lib64/libz.so.1.2.7
      5764:20191127:000520.436 7f37938f7000-7f37938f8000 r--p 00014000 fd:00 13771                      /usr/lib64/libz.so.1.2.7
      5764:20191127:000520.436 7f37938f8000-7f37938f9000 rw-p 00015000 fd:00 13771                      /usr/lib64/libz.so.1.2.7
      5764:20191127:000520.436 7f37938f9000-7f379391b000 r-xp 00000000 fd:00 736                        /usr/lib64/ld-2.17.so
      5764:20191127:000520.436 7f3793aca000-7f3793b00000 rw-s 00000000 00:04 1081345                    /SYSV00000000 (deleted)
      5764:20191127:000520.436 7f3793b00000-7f3793b11000 rw-p 00000000 00:00 0
      5764:20191127:000520.436 7f3793b15000-7f3793b16000 rw-p 00000000 00:00 0
      5764:20191127:000520.437 7f3793b16000-7f3793b17000 rw-s 00000000 00:04 1048576                    /SYSV00000000 (deleted)
      5764:20191127:000520.437 7f3793b17000-7f3793b1a000 rw-p 00000000 00:00 0
      5764:20191127:000520.437 7f3793b1a000-7f3793b1b000 r--p 00021000 fd:00 736                        /usr/lib64/ld-2.17.so
      5764:20191127:000520.437 7f3793b1b000-7f3793b1c000 rw-p 00022000 fd:00 736                        /usr/lib64/ld-2.17.so
      5764:20191127:000520.437 7f3793b1c000-7f3793b1d000 rw-p 00000000 00:00 0
      5764:20191127:000520.437 7ffeba2a0000-7ffeba2c1000 rw-p 00000000 00:00 0                          [stack]
      5764:20191127:000520.437 7ffeba2f1000-7ffeba2f3000 r-xp 00000000 00:00 0                          [vdso]
      5764:20191127:000520.437 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
      5764:20191127:000520.437 ================================
      5764:20191127:000520.437 Please consider attaching a disassembly listing to your bug report.
      5764:20191127:000520.437 This listing can be produced with, e.g., objdump -DSswx zabbix_agentd.
      5759:20191127:000520.437 One child process died (PID:5764,exitcode/signal:1). Exiting ...
      5759:20191127:000520.438 Zabbix Agent stopped. Zabbix 4.4.2 (revision 6d7579cc01).
  • sancho
    • Mar 2015
    • 301
    The agent of this version has problems, they have removed it.
    The solution is to downgrade the agent to version 4.4.1 and wait for a new version.
