Discovery reinstates deleted hosts
  • jlaw
    • Nov 2019
    Hi
    I've probably got something skew here but im not really sure where to look beyond the gui, i can tail logs quite happily but not 100% on where to look for this one.
    In the past i had a few servers that were monitored and discovered all good, these servers have since been switched off/deleted and then deleted from the Zabbix gui (configurations > hosts )however when the discovery rules run they keep re-adding the IP and associated templates from the actions linked to the discovery rules. I then get notifications to say they are unavailable/unreachable!
    The discovery check is simply
    "Zabbix agent "system.hostname""
    The IP's are not used for anything and essentially dead but these machines keep coming back from the dead!
    version - Zabbix 4.2.8
    thanks
  • cjbidwell
    • Dec 2019
    • 16
    Did you ever resolve this? I'm having the same issue.
    • jlaw
      • Nov 2019
      sorry just seen this notification!
      I did but couldn't tell you for sure how as i ended up just disabling the hosts and ignoring them in the end, it was either a mix of recreating the discovery rules and or updating the server to a newer version but it seems to have stopped!
      • MaryLowe
        • Mar 2021
        Originally posted by jlaw
        Hi
        In the past i had a few servers that were monitored and discovered all good, these servers have since been switched off/deleted and then deleted from the Zabbix gui (configurations > hosts )however when the discovery rules run they keep re-adding the IP and associated templates from the actions linked to the discovery rules. I then get notifications to say they are unavailable/pupilpath!
        thanks
        The available options for easily maintaining and structuring hosts can be menu, by selecting the Check_MK Discovery service with the button With this you can delete explicit attributes from the selected hosts and reinstate.
