SOLVED
Sorry everyone, it was a typo on my part, i put my machines IP as a hostname and the GT-105-213 as the visible name -.- I feel stupid.
I'm going to leave this post up for now, as some of the firewall info/telnet info may help others to diagnose their own problems. Mods, feel free to delete if you so choose.
Hey all,
I've just built a brand new setup of Zabbix on a HP G8 dl360, with 2 SSD's in RAID1. After verifying with a prebuilt version that Zabbix can satisfy many of my needs.
It's running Ubuntu 14.04, and i have everything setup properly / the same as the precompiled version I had used.
My hostname in the frontend is the EXACT same as my machine, GT-105-213
Previously, when i got this error:
I discovered i had to open the firewall like this:
However with Ubuntu, i've completely disabled the firewall
But i still get that error in my agent logs.
I am also able to telnet to my server from my machine, pointing to 192.168.105.248 10051 AND 10050. I can telnet from my server to my machine via telnet 192.168.105.213 10050, but not via 10051.
Can anyone give me a hand? I know it's nothing with the agent, because these configs all worked perfectly before hand. Seems to just be something with Ubuntu firewall.
Hey all,
5592:20140930:123335.249 no active checks on server [192.168.105.248:10051]: host [GT-105-213] not found
SuSEfirewall2 open EXT TCP zabbix-trapper zabbix-agent Then reload the firewall rules: SuSEfirewall2 stop SuSEfirewall2 start
sudo ufw disable
zabbix@Zabbix:~$ telnet 192.168.105.213 10051 Trying 192.168.105.213... telnet: Unable to connect to remote host: Connection refused zabbix@Zabbix:~$ telnet 192.168.105.213 10050 Trying 192.168.105.213... Connected to 192.168.105.213. Escape character is '^]'. Connection closed by foreign host.
