I have started to turn on Encryption with some of the agents I have installed and those machines keep saying that they are unreachable then are OK. I have chekced and they are not going offline and both Linux (Ubuntu) and Windows machines are having the issue . When I checked the agent logs on both the linux and windows machines, the following error appears in both.
WINDOWS: TLS handshake set result code to 1: file ssl\statem\extensions.c line 1604: error:141FA0FD:SSL routines:tls_psk_do_binder:binder does not verify: TLS write fatal alert "illegal parameter"
LINUX: TLS handshake set result code to 1: file ../ssl/statem/extensions.c line 1604: error:141FA0FD:SSL routines:tls_psk_do_binder:binder does not verify: TLS write fatal alert "illegal parameter"
I have checked over and over the settings and I would assume that if I had the wrong settings it would not connect at all. I searched the forums but do not see this error in other posts.
Anyone know what the above error means and why if is coming up?
