Zabbix API issue.
  • HaveDill
    • Sep 2014
    • 103
    Zabbix API issue.
    I've previously followed this guide and had it functioning on a prebuild Zabbix ISO.
    I'm trying to reimplement it on a fresh Ubuntu version of Zabbix, however i keep running into issues.
    I've read that it is an authentication issue, but my user and password are correct. Also i've tried with the URL as both http://192.168.105.248/zabbix/api_jsonrpc.php and http://192.168.105.248/api_jsonrpc.php
    Can someone please give me some input?? This is really frustrating me and i can't find anything online.
    Also when i put print $res before line 62 i get this:
    HTTP/1.1 200 OK
    Date: Thu, 02 Oct 2014 16:21:07 GMT
    Server: Apache/2.4.7 (Ubuntu)
    X-Powered-By: PHP/5.5.9-1ubuntu4.4
    Access-Control-Allow-Origin: *
    Access-Control-Allow-Headers: Content-Type
    Access-Control-Allow-Methods: POST
    Access-Control-Max-Age: 1000
    Content-Length: 125
    Content-Type: application/json
    {"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"Incorrect method \"user.authenticate\"."},"id":0}
    HTTP/1.1 200 OK
    Content-Length: 101
    {"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"Not authorised."},"id":1}
    ^ With http://192.168.105.248/zabbix/api_jsonrpc.php
    ^ with http://192.168.105.248/api_jsonrpc.php
  • simoon
    • May 2014
    In Zabbix 2.4 user.login method from API must be called without the auth parameter in the JSON-RPC request.
    Watch for this method in your scripts and modify.
    Or install Zabbix 2.2
    • MgMonte
      • Feb 2010
      missing API methods in Zabbix 2.4
      There are many modifications in Zabbix 2.4 API .
      The method "user.authenticate" is no more available and in some other calls some parameters has changed .
      I had to modify the "api_jsonrpc.php" to allow many apps present on the market to continue working.
      In particular I had to change "user.authenticate" into "user.login" and to remove the "auth" parameter in the 'apiinfo.version' call.
      Massimo
