I have 14 devices being monitored by Zabbix, all RHEL 7 machines. The server is CentOS7. I'm attempting to monitor system services under systemd, by following the instructions in this guide:
All of the default templates work as intended and I have status for things like HD health, CPU usage, etc. Everything looks as it should and I don't see any errors in the frontend. I have debug set to 3, and in the agent logs on a monitored system, I see where the agent runs through the systemctl checks for all the services its discovered. However, it does not report service status to the frontend.
A few notes that may be important:
The Zabbix server is in a different subnet than the devices being monitored. In the past, I've had a server/agent on the same subnet, and I did not experience the same issues.
The templates I'm using are set to "Zabbix agent", not "Zabbix agent active"
Thank you for any help, please let me know if I can provide more info.
