Lastest data empty for trapper value
  • tlacroix
    • Dec 2013
    • 30
    Hey there,
    I've configured that script to remotely get warranties of my Dell servers, and push the value to my server (key item - Log)
    Script is started by a cron on my server, once a week
    When I manually start the script and I check lastest data for my host, all values are here
    If I check a few hours later, the columns "last check" and "last value" are empty
    So I have to go to the History button to have values
    What do I have to configure in order to always have the lastest check and value visible in my lastest data, even if the values will be updated once a week ?
    Thank you!
  • tlacroix
    • Dec 2013
    • 30
    Okay, nice.
    Thank you!
    • MarcDo
      • Mar 2023
      Hey, what was the solution?
      I have the same problem and this is the only post I could find about it.
        • 4996
        By default, only values that fall within the last 24 hours are displayed. This limit has been introduced with the aim of improving initial loading times for large pages of the latest data. This time period can be extended by changing the value of the Max history display period parameter in Administration → General → GUI.​
