Need help setting up agentless ping response time graph
  • DFF Support
    • Sep 2019
    • 9
    Hi all,
    I'm a little new in trying to setup Agentless monitoring, but have been pretty successful setting up agents, triggers, actions, etc.
    I've setup a new template called, "Agentless Template" and have created one new item and one new graph.
    Item
    Name: "Ping Response Time"
    Key: icmppingsec[<target>,<packets>,<interval>,<size>,<timeout>,<mo de>]
    Interval: 30 sec
    History & Trends @ default
    Graph
    Width: 900
    Height: 200
    Graph type: Normal
    Items: Points to the new Item above
    The agentless host is using this new template, but I keep getting told when trying to create the widget in Monitoring that there's no data and the Item isn't supported?
  • Atsushi
    • Aug 2013
    • 2028
    Is icmppingsec item set as they are in the attached image? Select Simple check as the item type. Do not specify the argument of icmppingsec or specify a specific value such as target or packet. <target>, <packets>, etc. are not specified as arguments as they are, meaning that each value can be omitted or specified.
    As an example, please refer to the setting of item in Template Module ICMP Ping.
    • DFF Support
      • Sep 2019
      • 9
      https://www.zabbix.com/documentation.../simple_checks
      Sorry, I did change that to 'Simple check' (wrong pic posted) and I wasn't able to change the values when I tried to select the values in the Key field for some reason which made me think for some reason the values were set somewhere else.
      I'll try changing them again. - thanks
