Action remote script problem
  • rappa
    • Oct 2014
    I have a remote command that i use i Actions, but when i set Recovery message up it will not execute the command.
    /usr/lib/zabbix/externalscripts/baam.sh '{TRIGGER.NAME}' '{TRIGGER.STATUS}' '{TRIGGER.SEVERITY}' '{HOST.NAME1}' '{ITEM.NAME1}' '{ITEM.VALUE1}' '{TRIGGER.URL}'
    Conditions are
    not in maintenance
    Trigger Value : PROBLEM
    Trigger Severity: High
    Trigger Severity: Warning etc...
    Recovery Message: Check
    When i set the Trigger Value = OK , i see the command is executed however i also notice all the alerts from Auto Registration are triggered with Status OK which is conflicting.
    I have two steps in this action Remote command and email alert. Email works as expected. Remote command doesn't
    I have just upgraded to Version 2.2.3 and this broke as of our work flows.
    I see two possibilities, either specifically disable Status OK message when servers Auto registers and second option is to run a recovery command when the event recovers.
    PLEASE HELP ME...
    seems like this post has the same problem: https://www.zabbix.com/forum/showthread.php?t=46621
