zabbix_agentd gaps in data
  • crashdummyMCH
    • Jun 2006
    • 33
    I am experience a problem with zabbix during high loads.
    What happens is that zabbix does not retrieve any data for a period of time. My guess is that it is not getting any process time during these high loads. I also noticed that by default zabbix_agentd runs with a nice value of 5.
    in the zabbix_agentd.conf:
    timeout=25
    in the zabbix_server.conf:
    # Number of pre-forked instances of pollers
    # Default value is 6
    # This parameter must be between 5 and 255
    StartPollers=24
    # Number of pre-forked instances of trappers
    # Default value is 5
    # This parameter must be between 2 and 255
    StartTrappers=24
    # How often ZABBIX will try to send unsent alerts
    # (in seconds)
    # Default value is 30 seconds
    SenderFrequency=30
    in the zabbix_server.log i get the following:
    003010:20060823:130317 The value is not stored in database.
    003044:20060823:130317 Timeout while receiving data from [bbapp6]
    003044:20060823:130317 Getting value of [apache.bytesperreq] from host [bbapp6] failed
    003044:20060823:130317 The value is not stored in database.
    003012:20060823:130317 Timeout while receiving data from [bbapp6]
    003012:20060823:130317 Getting value of [net.if.in[eth0]] from host [bbapp6] failed
    This happens for ALL ITEMS MONITORED
    Also, immediately after the load cameback down data started coming in again. So I really think this is a zabbix_agentd issue.
    Is there a way to solve this or is there at the very least a way to monitor for this?
