USerParameter Not Working On FreeBSD ?
  • motilevy
    • May 2005
    Hi ,
    I am trying to get zabbix working and have some issues.
    i have the following commnad in agentd.conf .
    UserParameter=custom.root_free,/bin/df -m / | /usr/bin/grep dev | /usr/bin/awk '{print $4}'
    output looks fine when i run it via shell
    but server reports :
    008870:20060824:235000 Parameter [custom.root_free] is not supported by agent on host [MON01] Old status [0]
    OS : FreeBSD mon01 5.4-RELEASE-p12 FreeBSD 5.4-RELEASE-p12 #2: Mon Aug 14 17:33:45 GMT 2006
    Server : zabbix_server -v
    ZABBIX Server (daemon) v1.1.1 (19 July 2006)
    Compilation time: Aug 24 2006 19:50:50
    zabbix_agentd -v
    ZABBIX Agent (daemon) v1.1.1 (19 July 2006)
    help ?
  • edeus
    • Aug 2005
    • 120
    Zabbix agent runs under reduced privilleges so always try running your commands under the zabbix user account first.
    But I think your problem is the $4. Zabbix would be substituting an imaginary parameter 4. Add a space which is still awk "OK".
    UserParameter=custom.root_free,/bin/df -m / | /usr/bin/grep dev | /usr/bin/awk '{print $ 4}'
    Suggestion to zabbix: Only substitute when a UserParameter has values[].
