Hi
I am upgrading zabbix-server from version 3.4.8 to version 4.4.4 via compiling binaries from the source. I am dumping database from production zabbix setup, then i install the same zabbix version
on stage, and restore the database.
Finally i start upgrading process
Zabbix-4.4.4 configured and compiled successfully, but when starting new 4.4.4 binary i get the following error message from zabbix_server.log
Searching in google how to modify db schema/add table did not bring any reasonable results about this specific table.
Please advise
28828:20200102:185856.087 Starting Zabbix Server. Zabbix 4.4.4 (revision 3131fdac04). 28828:20200102:185856.087 ****** Enabled features ****** 28828:20200102:185856.087 SNMP monitoring: YES 28828:20200102:185856.087 IPMI monitoring: YES 28828:20200102:185856.087 Web monitoring: YES 28828:20200102:185856.087 VMware monitoring: YES 28828:20200102:185856.087 SMTP authentication: YES 28828:20200102:185856.087 ODBC: NO 28828:20200102:185856.087 SSH2 support: YES 28828:20200102:185856.087 IPv6 support: YES 28828:20200102:185856.087 TLS support: NO 28828:20200102:185856.088 ****************************** 28828:20200102:185856.088 using configuration file: /usr/local/etc/zabbix_server.conf 28828:20200102:185856.100 current database version (mandatory/optional): 03050000/03050000 28828:20200102:185856.100 required mandatory version: 04040000 28828:20200102:185856.101 [Z3005] query failed: [1146] Table 'zabbix.widget' doesn't exist [select wf.widgetid,wf.name from widget w,widget_field wf where w.widgetid=wf.widgetid and w.type='problems' and wf.name like 'tags.tag.%'] 28828:20200102:185856.101 database upgrade failed
Please advise
