Zabbix Proxy to Zabbix Server Connection is intermittent
  • satheshr90
    • Jan 2020
    It looks like connectivity between Zabbix Server in cloud and zabbix proxy is not stable and is intermittent with following set of errors:
    In Proxy Server:
    29466:20200103:015229.357 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:020729.382 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:022229.404 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:023729.429 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:025229.455 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:030729.481 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:032229.504 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:033729.531 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:035229.558 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:040729.584 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    29466:20200103:042229.610 cannot obtain configuration data from server at "x.x.x.x": ZBX_TCP_READ() timed out
    In Zabbix Server:
    107856:20200103:035732.068 sending configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X", datalen 1033428
    107856:20200103:040232.069 cannot send configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X": ZBX_TCP_WRITE() timed out
    107856:20200103:041232.162 sending configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X", datalen 1033428
    107856:20200103:041732.162 cannot send configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X": ZBX_TCP_WRITE() timed out
    107861:20200103:042732.261 sending configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X", datalen 1033428
    107861:20200103:043232.261 cannot send configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X": ZBX_TCP_WRITE() timed out
    107862:20200103:044232.364 sending configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X", datalen 1033428
    107862:20200103:044732.364 cannot send configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X": ZBX_TCP_WRITE() timed out
    107858:20200103:045732.464 sending configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X", datalen 1033428
    107858:20200103:050232.465 cannot send configuration data to proxy "XXXXXXXXXXXXX" at "10.X.X.X": ZBX_TCP_WRITE() timed out
    From n/w side, MTU is set at 1500. But still n/w team is looking for some options to see what is missing. But still wanted to know, what else could be the issue here? Please help.
  • namanjohnson101
    • Oct 2019
    Hey all,
    movies
    We are experiencing an issue in our Zabbix environment where the zabbix agent reports as being unreachable, but we can still ping the host and the service is running.
    We are currently using agent.ping for the item and our trigger is {host.name:agent.ping.nodata(5m)}=1
    Our graph shows the below.
