zabbix 4.4 api host.update tags error
  • pysany
    • Jan 2020
    When you attempt to add a tag using host.update as an API, the following error occurs.
    Error:
    {'error': {'data': 'Invalid parameter "/tags/1": an array is expected.', 'message': 'Invalid params.', 'code': -32602}, 'jsonrpc': '2.0', 'id': '0'}
    Requested Parameter
    {"params": {"hostid": "10272", "tags": {"value": "test", "tag": "role"}}, "jsonrpc": "2.0", "id": "0", "method": "host.update", "auth": "eb9149e5b05b7fbf41bb753c76698d55"}
    zabbixUrl="http://192.168.0.42/zabbix/api_jsonrpc.php"
    data = {
    "jsonrpc": "2.0",
    "params": {
    "hostid":hostId,
    #"inventory_mode":0,
    #"inventory":{
    # "location":"Latvia, Riga"
    #} # This code is no problem.
    "tags": {
    "tag": tagName,
    "value": tagValue
    "auth": token,
    "id":"0"
    zabbix version : 4.4
    Please help me
  • Markku
    • Sep 2018
    • 1790
    Hi, it says "array is expected", and you currently pass a dictionary. Have you tried this (= passing a one-item list of dictionaries):
    "tags": [
            "tag": tagName,
            "value": tagValue
    • pysany
      pysany commented
      Thank you! Good~
