Proxy PSK Errors
  • Nate01
    • Jan 2020
    Proxy PSK Errors
    I am attempting to implement a proxy into our Zabbix setup, although all hosts monitored through the proxy are receiving PSK errors. I am not having any issues with the hosts when monitoring without the proxy. I have attempted to configure new hosts and re-configure existing hosts, but they receive the same errors.
    I am running version 4.4.4 across the Zabbix server, proxy and agent.
    This is all running on CentOS 7.7 servers.
    Errors on Zabbix Server
    autoregistration from "HOST-IP" denied (host:"HOSTNAME" ip:"HOST-IP" port:10050): connection type "TLS with PSK" is not allowed for autoregistration
    cannot send list of active checks to "HOST-IP": host [HOSTNAME] not found
    Errors on Zabbix Agent (Monitored Host)
    active check configuration update from [PROXY-IP:10051] started to fail (TCP successful, cannot establish TLS to [[PROXY-IP]:10051]: SSL_connect() set result code to SSL_ERROR_SSL: file s3_pkt.c line 1493: error:1409445B:SSL routines:ssl3_read_bytes:reason(1115): SSL alert number 115: TLS read fatal alert "unknown PSK identity")
    Errors on Proxy
    cannot find requested PSK identity "HOSTNAME-RANDOM_DIGITS"
    failed to accept an incoming connection: from HOST-IP: TLS handshake set result code to 1: file s3_srvr.c line 2819: error:1408B0DF:SSL routines:ssl3_get_client_key_exchange:psk identity not found: TLS write fatal alert "unknown PSK identity"
    Zabbix Agent (Monitored Host) Config
    Server=PROXY-IP
    ServerActive=PROXY-IP
    TLSConnect=psk
    TLSAccept=psk
    TLSPSKIdentity=HOSTNAME-RANDOM_DIGITS
    TLSPSKFile=/etc/zabbix/zabbix_agent.psk
    Frontend is configured with PSK encryption TO and FROM host.
    Proxy Config
    Server=ZABBIX-SERVER-IP
    TLSConnect=psk
    TLSAccept=psk
    TLSPSKFile=/etc/zabbix/zabbix_proxy.psk
    Frontend is configured with PSK encryption FROM proxy (TO option is grayed out).
    Any assistance in troubleshooting this issue would be greatly appreciated.
  • Nate01
    • Jan 2020
    Update - I am no longer having the issue after switching the Proxy to Passive instead of Active. Not necessarily sure why Active was having issues with the PSK encryption, but the issue does not occur with Passive mode.
    • andris
      Zabbix developer
      • Feb 2012
      • 228
      Proxy in Active mode should work, too. Maybe proxy config was not yet updated from server when you saw error messages?
