Failed sending data to the peer: DATA failed: 550
  • Btaffo
    • Jan 2020
    Dear,
    I received the following message when trying to send an email: Failed sending data to the peer: DATA failed: 550.
    What could this problem be due to?
  • Atsushi
    • Aug 2013
    • 2028
    There may be errors or missing settings in the media settings. Please check the media settings.
    • Btaffo
      • Jan 2020
      the settings are ok, even sometimes the actions are sent to me as in others with error, the problem is intermittent, but I don't know why.
      • ralzenati
        ralzenati commented
        I am facing the same problem have you found a solution
      • many07
        many07 commented
        Hello, i have the same problem. How can i fix it ?
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Explanation of SMTP error 550: https://www.ionos.com/community/emai...-relay-denied/
      • chimer
        • Apr 2021
        This error 550 happens when the customers try to upload files from the wrong directory. For example, when the file is present in the folder /home/user/abc html, an attempt to upload from the path /home will cause this error. This error also happens when customer uses the relative path in FTP.
        omegle chat club
