The Zabbix server is not running
  • coulou78
    • Jan 2020
    I apologize in advance for my very bad English ... So, I just installed zabbix but cannot launch it...
    It tells me :
    zabbix server is not running the information displayed may not be.
    My last log to /var/log/zabbix/zabbix_agentd.log :
    3684:20200116:113125.597 Starting Zabbix Agent [Zabbix server]. Zabbix 4.0.16 (revision 9377bec666).
    3684:20200116:113125.597 **** Enabled features ****
    3684:20200116:113125.597 IPv6 support: YES
    3684:20200116:113125.597 TLS support: YES
    3684:20200116:113125.597 **************************
    3684:20200116:113125.597 using configuration file: /etc/zabbix/zabbix_agentd.conf
    3684:20200116:113125.597 agent #0 started [main process]
    3686:20200116:113125.611 agent #2 started[listener #1]
    3687:20200116:113125.613 agent #3 started[listener #2]
    3688:20200116:113125.614 agent #4 started[listener #3]
    3689:20200116:113125.615 agent #5 started [active checks #1]
    3685:20200116:113125.617 agent #1 started [collector]
    3689:20200116:113125.617 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused)
    3684:20200116:121650.855 Got signal [signal:15(SIGTERM),sender_pid:6496,sender_uid:987, reason:0]. Exiting ...
    3684:20200116:121650.857 Zabbix Agent stopped. Zabbix 4.0.16 (revision 9377bec666).
    6500:20200116:121650.874 Starting Zabbix Agent [Zabbix server]. Zabbix 4.0.16 (revision 9377bec666).
    6500:20200116:121650.874 **** Enabled features ****
    6500:20200116:121650.874 IPv6 support: YES
    6500:20200116:121650.874 TLS support: YES
    6500:20200116:121650.874 **************************
    6500:20200116:121650.874 using configuration file: /etc/zabbix/zabbix_agentd.conf
    6500:20200116:121650.874 agent #0 started [main process]
    6505:20200116:121650.880 agent #5 started [active checks #1]
    6501:20200116:121650.883 agent #1 started [collector]
    6502:20200116:121650.883 agent #2 started[listener #1]
    6503:20200116:121650.884 agent #3 started[listener #2]
    6504:20200116:121650.886 agent #4 started[listener #3]
    6505:20200116:121650.887 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused)
    Do you have any solutions pls ?
  • Atsushi
    • Aug 2013
    • 2028
    Check the status of Zabbix server, not Zabbix agent.
    Is the zabbix_server process started?
    Is the communication from the web server to the zabbix_server process restricted by the SELinux settings, etc.?
