zabbix server not running
  • alyssoncv
    • Jan 2020
    The zabbix server was configured in ubunto 18. After placing some hosts via snmp. the zabbix server service has stopped. logs.
    Zabbix Server stopped. Zabbix 4.4.4 (revision 3131fdac04).
    5136:20200120:135224.301 Starting Zabbix Server. Zabbix 4.4.4 (revision 3131fdac04).
    5136:20200120:135224.301 ****** Enabled features ******
    5136:20200120:135224.301 SNMP monitoring: YES
    5136:20200120:135224.301 IPMI monitoring: YES
    5136:20200120:135224.301 Web monitoring: YES
    5136:20200120:135224.301 VMware monitoring: YES
    5136:20200120:135224.301 SMTP authentication: YES
    5136:20200120:135224.301 ODBC: YES
    5136:20200120:135224.301 SSH2 support: YES
    5136:20200120:135224.301 IPv6 support: YES
    5136:20200120:135224.301 TLS support: YES
    5136:20200120:135224.301 ******************************
    5136:20200120:135224.301 using configuration file: /etc/zabbix/zabbix_server.conf
    5136:20200120:135224.311 current database version (mandatory/optional): 04040000/04040000
    5136:20200120:135224.311 required mandatory version: 04040000
    5136:20200120:135224.317 server #0 started [main process]
    5139:20200120:135224.317 server #1 started [configuration syncer #1]
    5139:20200120:135224.707 __mem_malloc: skipped 0 asked 192 skip_min 18446744073709551615 skip_max 0
    5139:20200120:135224.707 [file:dbconfig.c,line:94] __zbx_mem_realloc(): out of memory (requested 192 bytes)
    5139:20200120:135224.707 [file:dbconfig.c,line:94] __zbx_mem_realloc(): please increase CacheSize configuration parameter
    5139:20200120:135224.707 === memory statistics for configuration cache ===
    5139:20200120:135224.707 free chunks of size 24 bytes: 116
    5139:20200120:135224.707 free chunks of size 32 bytes: 22
    5139:20200120:135224.707 free chunks of size 80 bytes: 1
    5139:20200120:135224.707 min chunk size: 24 bytes
    5139:20200120:135224.707 max chunk size: 80 bytes
    5139:20200120:135224.707 memory of total size 8388232 bytes fragmented into 72665 chunks
    5139:20200120:135224.707 of those, 3568 bytes are in 139 free chunks
    5139:20200120:135224.707 of those, 7222040 bytes are in 72526 used chunks
    5139:20200120:135224.707 ================================
    5139:20200120:135224.707 === Backtrace: ===
    5139:20200120:135224.708 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x4e) [0x559376f8b558]
    5139:20200120:135224.708 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x559376f868e7]
    5139:20200120:135224.708 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x18ad93) [0x559376f4cd93]
    5139:20200120:135224.708 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1cdceb) [0x559376f8fceb]
    5139:20200120:135224.708 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashmap_set+0xf3) [0x559376f9010b]
    5139:20200120:135224.708 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_binary_heap_insert+0xfc) [0x559376f8dcf3]
    5139:20200120:135224.708 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x18bbfa) [0x559376f4dbfa]
    5139:20200120:135224.708 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x19269b) [0x559376f5469b]
    5139:20200120:135224.708 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0xb97) [0x559376f59fae]
    5139:20200120:135224.708 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x10c) [0x559376e116cc]
    5139:20200120:135224.708 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x559376f995c7]
    5139:20200120:135224.708 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x991) [0x559376e03149]
    5139:20200120:135224.708 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x559376f8ac81]
    5139:20200120:135224.708 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x305) [0x559376e027a2]
    5139:20200120:135224.708 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fd2a232cb97]
    5139:20200120:135224.708 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2a) [0x559376e0181a]
    5136:20200120:135224.711 One child process died (PID:5139,exitcode/signal:1). Exiting ...
    5136:20200120:135224.711 syncing trend data...
    5136:20200120:135224.711 syncing trend data done
    5136:20200120:135224.711 Zabbix Server stopped. Zabbix 4.4.4 (revision 3131fdac04).
  • Markku
    • Sep 2018
    • 1784
    I would try to do exactly that: increase CacheSize
    Markku
    • alyssoncv
      • Jan 2020
      it worked! thanks!
