Screen graphs delayed (after upgrade to 4.0.16)
  • arrayown
    • Jan 2017
    After upgrading from a previous 4.0.x version to version 4.0.16, I noticed that graphs on my Screens page are always showing 2 minutes late. When I view the graphs individually on the Graphs page, they show up fine. There is nothing in the queue and the agents are reporting data every 1m.
    See screenshot as an example.
    Can someone please help me troubleshoot this?
    Thanks!
    Click image for larger version  Name:	zabbix-delayed-chart.png Views:	0 Size:	17.2 KB ID:	393979
  • Markku
    • Sep 2018
    • 1784
    Hi, see https://support.zabbix.com/browse/ZBX-17105 for information and workaround.
    Markku
    • arrayown
      • Jan 2017
      Thank you very much. I was able to fix my issue.
      Looking forward to 4.0.17.
      Best regards.
      • thawzinhtun
        • Jan 2020
        how to upgrade 4.0.16 to 4.0.17
        • Markku
          • Sep 2018
          • 1784
          Reading the documentation and going from there, when 4.0.17 is released: https://www.zabbix.com/documentation...lation/upgrade
          Markku
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            If you're using packages from official Zabbix repository then it's just
            sudo apt update && sudo apt upgrade
            or
            sudo yum upgrade
            depending on your GNU/Linux distribution.
