Graphs lag
  • lyric
    • May 2012
    Graphs lag
    Hello, I have zabbix 4.4 installed and worked correctly for a long time.
    Yesterday ran "yum update" command (CentOS 7.7.1908) and updated everything with no errors.
    Immediately after the update, I found all graphs drawing several minutes lag from the real time.
    Now the version is 4.4.4
    I know the previos version was 4.4.*, but don't know which one exactly.
    You can see that zabbix knows correct current time, but draws with delay.
Name:	Снимок экрана 2020-01-24 в 14.18.55.png
    I've checked:
    System time: command "date") - correct
    php time: echo date("H:i:s"); - correct
    mysql time: select now(); - correct
    MySQL load is very low
    Administration -> Queue in zabbix GUI - all the zeros.
    What else could be wrong and what can I check?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    • lyric
      • May 2012
      dimir, thank you!
