I've followed this tutorial on a Zabbix server and 2 agents:
All 3 servers are completely new Ubuntu 14.04 LTS with no firewall/IP-tables rules.
My first agent shows this in the log when restarting:
19268:20141030:122027.549 Got signal [signal:15(SIGTERM),sender_pid:19980,sender_uid:0,r eason:0]. Exiting ...
19268:20141030:122029.550 Zabbix Agent stopped. Zabbix 1.8.11 (revision 26205).
19996:20141030:122029.571 Starting Zabbix Agent [metadata]. Zabbix 1.8.11 (revision 26205).
19998:20141030:122029.571 agent #1 started [active checks]
19997:20141030:122029.572 agent #0 started [collector]
In Zabbix server the status of that agent is error.
Connection refused to the IP.
My second agent shows this in the log when restarting:
1892:20141030:122244.943 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
1891:20141030:122244.944 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
1890:20141030:122244.947 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
1887:20141030:122244.947 One child process died (PID:1891,exitcode/signal:255). Exiting ...
1893:20141030:122244.948 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
1889:20141030:122244.953 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
1887:20141030:122244.955 Zabbix Agent stopped. Zabbix 2.2.2 (revision 42525).
1996:20141030:122245.012 Starting Zabbix Agent [3d]. Zabbix 2.2.2 (revision 42525).
1996:20141030:122245.012 using configuration file: /etc/zabbix/zabbix_agentd.conf
1999:20141030:122245.028 agent #1 started[listener #1]
1998:20141030:122245.028 agent #0 started [collector]
2000:20141030:122245.031 agent #2 started[listener #2]
2001:20141030:122245.032 agent #3 started[listener #3]
2002:20141030:122245.032 agent #4 started [active checks #1]
2002:20141030:122245.036 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused)
In Zabbix server the status of that agent is OK.
That seems weird. What to due? I'm new to Zabbix, but would like both servers to be monitored actively.
