Zabbix Action Default Message
  • sangcheol1
    • Feb 2020
    Hello.
    I'm preparing a Zavics alert message.
    I want to use Hangul in basic message and add pictures.
    Is it possible?
    Let me know if I can.
  • tim.mooney
    • Dec 2012
    • 1436
    Versions of Zabbix since 4.2.0alpha1 have the ability to send HTML email messages. If you can write Hangul in the HTML message, Zabbix should be able to send it.
    I don't how difficult it is to include pictures directly in the HTML message you send, but your HTML email could certainly reference pictures (a href=) . The only thing to consider is whether the web server hosting those pictures will be reachable/available in the event of a network outage or other issue.
    • sangcheol1
      sangcheol1 commented
      I supplied in sending mail to version 4.2 with your help.
      Can't you send html mail with version 4.0?
  • sangcheol1
    • Feb 2020
    I supplied in sending mail to version 4.2 with your help. Thank you
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Unfortunately, no. As tim.mooney mentioned this is a feature that came in 4.2: https://www.zabbix.com/documentation..._notifications
