Problem with connect zabbix agent to server
  • ipsec
    • Feb 2020
    Hello My zabbix server is ​​running on the router in the eth1 local network -> 192.168.1.1 port 10051 I installed zabbix agent on the windnows7 system on a local computer with the address 192.168.1.2 port 10051 From a computer, I can log in to the administration panel. However, after adding the zabbix host, the server cannot see the agent. Does anyone have a tip for me where I made the mistake?
    (Zabbix) 4.4.5
    Revision b93f5c4fc0 28 January 2020, compilation time: Jan 30 2020 11:27:03
    Compiled with OpenSSL 1.1.1c 28 May 2019
    Running with OpenSSL 1.1.1d 10 Sep 2019
    Both zabbix server and zabbix agent are running correctly. There are no errors or warnings in the log files.
  • Markku
    • Sep 2018
    • 1784
    Zabbix agent is normally listening at port 10050, so please check that your agent port configuration matches with the host configuration in Zabbix GUI.
    Markku
    • cfrancis
      • Jun 2019
      • 17
      Sorry I was wrong.
      Greetings.
