sudo: no tty present and no askpass program specified
  • slence
    • Nov 2014
    • 41
    I'm trying to get the "Result of "Detect operating system" and have the following error:
    - sudo: no tty present and no askpass program specified
    I've try to put zabbix user in /etc/sudoers , but the error still remain.
    After put the user there, i've restarted the agent.
    I've other graphs that don't have data, says "no data"
    Can someone help me?
    Thanks.
  • kustodian
    • Oct 2012
    • 33
    Try to comment out the following line in /etc/sudoers so it looks like this:
    #Defaults       requiretty
    • slence
      • Nov 2014
      • 41
      hi,
      thanks for you reply.
      I don't have that line in sudoers :\
      • kustodian
        • Oct 2012
        • 33
        Originally posted by slence
        hi,
        What OS are you using? Have you searched for that line without '#'?
        • slence
          • Nov 2014
          • 41
          hi:
          The SO:
          Distributor ID: Ubuntu
          Description: Ubuntu 12.04.5 LTS
          Release: 12.04
          Codename: precise
          I've searched for that line and nothing.
          • kustodian
            • Oct 2012
            • 33
            Then it's because you /etc/sudoers file isn't correctly set for the user which is running zabbix agent. Could you please paste the sudoers line for the zabbix agent user?
            • lagos.mc
              • Jan 2011
              Trying
              cat /etc/sudoers
              Sample:
              %zabbix ALL = (ALL) NOPASSWD: command
              Regards,
              • Farmhouse Geek
                • Mar 2015
                Resolved
                I'm using the 2.4 appliance and was getting this error, I've resolved it:
                The issue was the Zabbix server is actually running as user zabbixs and not zabbix (the agent user)
                You can add teh following to /etc/sudoers or create /etc/sudoers.d/zabbixs with the following
                zabbixs ALL=(ALL) NOPASSWD: /usr/bin/nmap -O *
                Once that was in place OS detection worked like a champ.
                • jstefano
                  • Sep 2015
                  • 30
                  Thank you!!! This solved my problem!!!
                  Jan
