CPU - Not Supported
  • slence
    • Nov 2014
    • 41
    CPU - Not Supported
    I need to get CPU Load from my servers, but the agent says:
    - NOT SUPPORTED
    i've create a new item:
    - system.cpu.load[percpu,avg1]
    And still nothing...no data!
    In the log, i've this:
    No active checks on server: host [xxxxx] not found
    Can someone help me?
  • slence
    • Nov 2014
    • 41
    hi,
    Please delete this.
    I've change my hostname in the host in zabbix and everything seems to work now.
    Thanks.
    • slence
      • Nov 2014
      • 41
      well, actually something is wrong...i've change something and stop working again...
      system.cpu.load[all,,] , can be this way, the item?
      in the server --> zabbix_agentd -t "system.cpu.load[all]"
      system.cpu.load[all] [d|21.100000]
      • kustodian
        • Oct 2012
        • 33
        It only supports two items, not three:
        system.cpu.load[<cpu>,<mode>] (documentation)
        You need to give out more information if you would like anyone to help you. Which zabbix version, what OS is zabbix agent running on, are you configuring a passive or active check?
        Also it's easiest to test agent items with running zabbix_get on the zabbix server host:
        zabbix_get -s HOST_IP -p 10050 -k "system.cpu.load[all,avg1]"
        • slence
          • Nov 2014
          • 41
          hi,
          after a few minutes of wait, everything seems to work again.
          So, just need to adjust the key and wait.
          Thanks.
