install zabbix agent offline on Debian 6.0
  • daler86
    • Nov 2012
    Hello
    I need help with installing offline zabbix agent on Debian 6.0 (Debian server haven't internet)
    I download package and move to debian server. When installing zabbix agent i have error
    dpkg -i zabbix-release_2.0-1squeeze_all.deb
    (Reading database ... 67467 files and directories currently installed.)
    Preparing to replace zabbix-release 2.0-1squeeze (using zabbix-release_2.0-1squeeze_all.deb) ...
    Unpacking replacement zabbix-release ...
    Setting up zabbix-release (2.0-1squeeze) ...
    sudo apt-get install zabbix-release_2.0-1squeeze_all.deb
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package zabbix-release_2.0-1squeeze_all.deb
    E: Couldn't find any package by regex 'zabbix-release_2.0-1squeeze_all.deb'
  • Atsushi
    • Aug 2013
    • 2028
    The zabbix-release package is a package for setting information to acquire various packages while connected to the Internet. Not used in offline environment without internet connection.
    If you only need Zabbix agent, try to get zabbix-agent package and install it with dpkg command. However, Zabbix 2.0 is no longer supported and its use is not recommended.
