Zabbix 4.4: wmi.getall[] - the problem is the value of the returned data
  • 4ernomor
    • Feb 2020
    Hi!
    The WMI query returns values of type Real32.
    When using wmi.get[] - the returned value is correct.
    When using wmi.get all [] - the return value is incorrect.
    Example:
    C:\Program Files\Zabbix Agent>zabbix_get -s 127.0.0.1 -k wmi.get[root\OpenHardwareMonitor,"select Max from sensor where (Parent LIKE '%RAM%' AND SensorType = \"Load\")"]
    79.757965
    C:\Program Files\Zabbix Agent>zabbix_get -s 127.0.0.1 -k wmi.getall[root\OpenHardwareMonitor,"select Max from sensor where (Parent LIKE '%RAM%' AND SensorType = \"Load\")"]
    [{"Max":4635312884778270720.}]
    [LEFT][COLOR=#252C2F][FONT="Open Sans"][/FONT][/COLOR][/LEFT]
    How to use wmi.getall [], get a human readable value?
  • tim.mooney
    • Dec 2012
    • 1430
    As the documentation for the Windows-specific item types points out, wmi.get[] returns one value, with a particular type (like Real32).
    wmi.getall[] instead returns a JSON Object, since it's designed to return multiple values of potentially different types.
    The comment for wmi.getall[] indicates you can use pre-processing to extract specific values. There's a link from the pre-processing area to the details about JSONPath in the appendix.
    • 4ernomor
      • Feb 2020
      Clarify (sorry for bad English):
      Key "wmi.getall[] " - returns a JSON object, but the Real32 data in this object is incorrect.
      Key "wmi.get[]" data of type Real32 returns as "79.757965", whereas the key is "wmi.getall[]" returns as "4635312884778270720."
      If you use JavaScript preprocessing, example of a built-in Zabbix template: "Template Module Windows physical disks by Zabbix", which uses JavaScript for Discovery rule "Physical disks discovery":
      output = JSON.parse(value).map(function(dev){
      return {
      "{#DEVNAME}": dev.Name,
      "{#DEVQUEUE}": dev.CurrentDiskQueueLength,
      "{#DEVREADS}": dev.DiskReadsPersec,
      "{#DEVTIME}": dev.PercentDiskTime,
      "{#DEVWRITES}": dev.DiskWritesPersec
      return JSON.stringify({"data": output})
      adapted in my case:
      return {
      "{#SENSORID}": dev.Identifier,
      "{#SENSORINDEX}": dev.Index,
      "{#SENSORINSTANCE}": dev.InstanceId,
      "{#SENSORMAX}": dev.Max,
      "{#SENSORMIN}": dev.Min,
      "{#SENSORNAME}": dev.Name,
      "{#SENSORPARENT}": dev.Parent,
      "{#SENSORPARENT}": dev.ProcessId,
      "{#SENSORTYPE}": dev.SensorType,
      "{#SENSORVAL}": dev.Value
      then an error is returned for a value with the type Real32:
      "SyntaxError: invalid json (at offset 86) at [anon] (duktape.c:34342) internal at parse () native strict preventsyield at [anon] (function:1) preventsyield"
      • tim.mooney
        • Dec 2012
        • 1430
        Your English was fine, I just misunderstood what the problem was. Sorry about that.
        You're correct that the returned "Max" value seems to be completely different, even though the query appears to be exactly the same. I don't know what's causing that.
        I'm not a strong JavaScript programmer, but I think you can't just take the "physical disks" JSON preprocessing and use that here. The reason is that the physical disks template
        must be returning a JSON Object named "dev", with keys for Identifier, Index, Min, Max, etc. But the WMI query you're getting isn't returning an object named "dev" with those keys.
