Zabbix Configuration for Monitoring Multiple Tomcat JVM on Single Host via JMX
  • Tejas
    • Feb 2020
    I have multiple instance of Tomcat on a single host running on different port. I have enabled JMX on each tomcat instance with 2 different port (9999 and 9998).
    -Dcom.sun.management.jmxremote
    -Dcom.sun.management.jmxremote.port=9999
    -Dcom.sun.management.jmxremote.rmi.port=9999
    -Dcom.sun.management.jmxremote.authenticate=false
    -Dcom.sun.management.jmxremote.ssl=false
    -Djava.rmi.server.hostname=10.1.2.3
    and
    -Dcom.sun.management.jmxremote.port=9998
    -Dcom.sun.management.jmxremote.rmi.port=9998
    I would like to monitor both jvm via zabbix. I'm using a Generic JVM template.
    I'm able to add a single JMX Interface via Configuration> Host> Create New Host > JMX Interface : 10.1.2.3:9999.
    I can view the Metrics/Graphs on Zabbix UI.
    Is it possible to another JMX entry (10.1.2.3:9998) under the same host ? Or do i need to create another host entry for port 9998 ?
    we have 15 hosts with each having 10 tomcat instances, hence would like to know what is the best way to do it ? Do i need to create 150 Host entries in Zabbix?
    Note: i'm using a older version of Zabbix (2.0.4) on Ubuntu 14. Tomcat version 9.0 running on Windows Server.Thanks !!
  • Gloomeye
    • Aug 2024
    For servers with multiple jmx roles, I applied the following method:
    1) I created 4 different JMX interfaces for 4 different Apache Tomcat installations and 4 different published ports on the same host.Click image for larger version
    2) I copied the Apache Tomcat by JMX template with a different name for each Tomcat.
    3) I defined the description as Port2/Port3/Port4 in the key fields using jmx for each template. (For example: jmx["Catalina:type=Server",serverInfo,Port4]) I did this in all Item, Discovery Rules, Item Prototypes, and Graph Prototypes Name fields.Click image for larger version
    However, this did not ensure that the newly created templates would select the correct JMX interface.
    4) To select the correct JMX interface, I selected the correct JMX interface from the host interface combo box on the host. I did this in all Item, Discovery Rules, and Item Prototypes key fields.Click image for larger version
    In this way, I could use 4 different Tomcat templates on a single host.
