I have a zabbix 2.2.7 (from web ui) on Centos7 running under nginx+php-fpm.
I can do changes in a map (add, remove, edit) and save them the first time. All the changes I do after that first 'save' will not be kept, even though the 'Map saved' message it's correctly displaying.
It doesn't matter if I continue in the map (accept on map saved popup) or if I cancel and go back editing that map later during the session: nothing will be saved after first save click. If I logout and in again I can save my new modifications again only for the first time I click on save.
I tried disabling all page caches in nginx/php-fpm I could, but no luck at all.
Anyone has an idea I can try
? (I've tried with Chrome and Firefox with same results)
Thanks in advance!
? (I've tried with Chrome and Firefox with same results)Thanks in advance!
