Zabbix template import problem
  • KellyG
    • Nov 2014
    Hi all, I'm new to Zabbix and new to here.
    We are using Zabbix v2.2.4 on CentOS 6.5.
    I have a problem importing an individual template with 77 hosts.
    Basically I have a template with 2968 lines that seems to timeout when uploading.
    I have modified the zabbix.conf increasing the memory_limit from 128M to 512M which seems to stop the time out but the task slows down massively and takes roughly 7 to 8 minutes to do the import.
    Are there any other settings I can play with?
  • ArtemK
    • May 2013
    • 232
    template doesn't contain any hosts. Do you have any errors zabbix showing to you? Maybe your web server refuses to accept huge files? Check php settings, web server/php logs
    • KellyG
      • Nov 2014
      Hi, yes the template contains no hosts.
      Thanks for the log file pointer it definately indicates I need to increase the memory allocation.
      "PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 32 bytes)"
