Server crash on startup "configuration syncer"
  • ebogaard
    • Nov 2019
    Out of nowhere, my Zabbix 4.4.6 server crashed after adding a new agent (might be related, might not be) and refuses to start again.
    It crashes on the "configuration syncer".
    This is in the logs when I try to start the server (debug level 5):
    17050:20200309:113116.149 Starting Zabbix Server. Zabbix 4.4.6 (revision 8cc702429d).
    17050:20200309:113116.149 ****** Enabled features ******
    17050:20200309:113116.149 SNMP monitoring: YES
    17050:20200309:113116.150 IPMI monitoring: YES
    17050:20200309:113116.150 Web monitoring: YES
    17050:20200309:113116.150 VMware monitoring: YES
    17050:20200309:113116.150 SMTP authentication: YES
    17050:20200309:113116.150 ODBC: YES
    17050:20200309:113116.150 SSH support: YES
    17050:20200309:113116.150 IPv6 support: YES
    17050:20200309:113116.151 TLS support: YES
    17050:20200309:113116.151 ******************************
    17050:20200309:113116.151 using configuration file: /etc/zabbix/zabbix_server.conf
    17050:20200309:113116.151 In zbx_load_modules()
    17050:20200309:113116.151 End of zbx_load_modules():SUCCEED
    17050:20200309:113116.151 In init_database_cache()
    17050:20200309:113116.151 In zbx_mem_create() param:'HistoryCacheSize' size:268435456
    17050:20200309:113116.151 valid user addresses: [0x7f94e6b53168, 0x7f94f6b52ff0] total size: 268435080
    17050:20200309:113116.151 End of zbx_mem_create()
    17050:20200309:113116.151 In zbx_mem_create() param:'HistoryIndexCacheSize' size:67108864
    17050:20200309:113116.151 valid user addresses: [0x7f94e2b53178, 0x7f94e6b52ff0] total size: 67108472
    17050:20200309:113116.151 In init_trend_cache()
    17050:20200309:113116.151 In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend cache' param:'TrendCacheSize'
    17050:20200309:113116.151 End of zbx_mem_required_size() size:414
    17050:20200309:113116.151 In zbx_mem_create() param:'TrendCacheSize' size:67108864
    17050:20200309:113116.151 valid user addresses: [0x7f94deb53168, 0x7f94e2b52ff0] total size: 67108488
    17050:20200309:113116.152 End of init_trend_cache()
    17050:20200309:113116.152 End of init_database_cache()
    17050:20200309:113116.152 In init_configuration_cache() size:268435456
    17050:20200309:113116.152 In zbx_mem_create() param:'CacheSize' size:268435456
    17050:20200309:113116.152 valid user addresses: [0x7f94ceb53168, 0x7f94deb52ff0] total size: 268435080
    17050:20200309:113116.152 End of zbx_mem_create()
    17050:20200309:113116.152 End of init_configuration_cache()
    17050:20200309:113116.152 In init_selfmon_collector()
    17050:20200309:113116.152 init_selfmon_collector() size:15480
    17050:20200309:113116.152 End of init_selfmon_collector() collector:0x7f94fde6a000
    17050:20200309:113116.152 In zbx_vc_init()
    17050:20200309:113116.152 In zbx_mem_required_size() size:0 chunks_num:1 descr:'value cache size' param:'ValueCacheSize'
    17050:20200309:113116.152 End of zbx_mem_required_size() size:419
    17050:20200309:113116.152 In zbx_mem_create() param:'ValueCacheSize' size:536870912
    17050:20200309:113116.152 valid user addresses: [0x7f94aeb53168, 0x7f94ceb52ff0] total size: 536870536
    17050:20200309:113116.152 End of zbx_vc_init()
    17050:20200309:113116.152 In zbx_db_get_database_type()
    17050:20200309:113116.152 In DBconnect() flag:0
    17050:20200309:113116.159 End of DBconnect():0
    17050:20200309:113116.159 query [txnlev:0] [select userid from users limit 1]
    17050:20200309:113116.160 there is at least 1 record in "users" table
    17050:20200309:113116.160 End of zbx_db_get_database_type():ZBX_DB_SERVER
    17050:20200309:113116.160 In DBcheck_version()
    17050:20200309:113116.160 In DBconnect() flag:0
    17050:20200309:113116.162 End of DBconnect():0
    17050:20200309:113116.162 query [txnlev:0] [show tables like 'dbversion']
    17050:20200309:113116.163 query [txnlev:0] [select mandatory,optional from dbversion]
    17050:20200309:113116.166 current database version (mandatory/optional): 04040000/04040001
    17050:20200309:113116.166 required mandatory version: 04040000
    17050:20200309:113116.167 End of DBcheck_version():SUCCEED
    17050:20200309:113116.167 In DBconnect() flag:0
    17050:20200309:113116.169 End of DBconnect():0
    17050:20200309:113116.169 query [txnlev:0] [SELECT default_character_set_name, default_collation_name FROM information_schema.SCHEMATA WHERE schema_name = 'zabbix01']
    17050:20200309:113116.169 query [txnlev:0] [SELECT COUNT(*) FROM information_schema.`COLUMNS` WHERE table_schema = 'zabbix01' AND data_type IN ('text', 'varchar', 'longtext') AND (character_set_name != 'utf8' OR collation_name != 'utf8_bin')]
    17050:20200309:113116.179 server #0 started [main process]
    17051:20200309:113116.179 server #1 started [configuration syncer #1]
    17051:20200309:113116.179 zbx_setproctitle() title:'configuration syncer [connecting to the database]'
    17051:20200309:113116.179 In DBconnect() flag:0
    17051:20200309:113116.181 End of DBconnect():0
    17051:20200309:113116.182 zbx_setproctitle() title:'configuration syncer [syncing configuration]'
    17051:20200309:113116.182 In DCsync_configuration()
    17051:20200309:113116.182 query [txnlev:0] [select refresh_unsupported,discovery_groupid,snmptrap_log ging,severity_name_0,severity_name_1,severity_name _2,severity_name_3,severity_name_4,severity_name_5 ,hk_events_mode,hk_events_trigger,hk_events_intern al,hk_events_discovery,hk_events_autoreg,hk_servic es_mode,hk_services,hk_audit_mode,hk_audit,hk_sess ions_mode,hk_sessions,hk_history_mode,hk_history_g lobal,hk_history,hk_trends_mode,hk_trends_global,h k_trends,default_inventory_mode,db_extension,autor eg_tls_accept from config order by configid]
    17051:20200309:113116.182 query [txnlev:0] [select tls_psk_identity,tls_psk from config_autoreg_tls order by autoreg_tlsid]
    17051:20200309:113116.183 In DCsync_config()
    17051:20200309:113116.183 End of DCsync_config()
    17051:20200309:113116.183 In DCsync_autoreg_config()
    17051:20200309:113116.183 End of DCsync_autoreg_config()
    17051:20200309:113116.183 query [txnlev:0] [select hostid,templateid from hosts_templates order by hostid]
    17051:20200309:113116.183 query [txnlev:0] [select globalmacroid,macro,value from globalmacro]
    17051:20200309:113116.184 query [txnlev:0] [select hostmacroid,hostid,macro,value from hostmacro]
    17051:20200309:113116.184 query [txnlev:0] [select * from host_tag]
    17051:20200309:113116.184 In DCsync_htmpls()
    17051:20200309:113116.185 End of DCsync_htmpls()
    17051:20200309:113116.185 In DCsync_gmacros()
    17051:20200309:113116.185 End of DCsync_gmacros()
    17051:20200309:113116.185 In DCsync_hmacros()
    17051:20200309:113116.185 End of DCsync_hmacros()
    17051:20200309:113116.185 In DCsync_host_tags()
    17051:20200309:113116.185 End of DCsync_host_tags()
    17051:20200309:113116.185 query [txnlev:0] [select hostid,proxy_hostid,host,ipmi_authtype,ipmi_privil ege,ipmi_username,ipmi_password,maintenance_status ,maintenance_type,maintenance_from,errors_from,ava ilable,disable_until,snmp_errors_from,snmp_availab le,snmp_disable_until,ipmi_errors_from,ipmi_availa ble,ipmi_disable_until,jmx_errors_from,jmx_availab le,jmx_disable_until,status,name,lastaccess,error, snmp_error,ipmi_error,jmx_error,tls_connect,tls_ac cept,tls_issuer,tls_subject,tls_psk_identity,tls_p sk,proxy_address,auto_compress,maintenanceid from hosts where status in (0,1,5,6) and flags<>2]
    17051:20200309:113116.187 query [txnlev:0] [select hostid,inventory_mode,type,type_full,name,alias,os ,os_full,os_short,serialno_a,serialno_b,tag,asset_ tag,macaddress_a,macaddress_b,hardware,hardware_fu ll,software,software_full,software_app_a,software_ app_b,software_app_c,software_app_d,software_app_e ,contact,location,location_lat,location_lon,notes, chassis,model,hw_arch,vendor,contract_number,insta ller_name,deployment_status,url_a,url_b,url_c,host _networks,host_netmask,host_router,oob_ip,oob_netm ask,oob_router,date_hw_purchase,date_hw_install,da te_hw_expiry,date_hw_decomm,site_address_a,site_ad dress_b,site_address_c,site_city,site_state,site_c ountry,site_zip,site_rack,site_notes,poc_1_name,po c_1_email,poc_1_phone_a,poc_1_phone_b,poc_1_cell,p oc_1_screen,poc_1_notes,poc_2_name,poc_2_email,poc _2_phone_a,poc_2_phone_b,poc_2_cell,poc_2_screen,p oc_2_notes from host_inventory]
    17051:20200309:113116.196 query [txnlev:0] [select groupid,name from hstgrp]
    17051:20200309:113116.197 query [txnlev:0] [select hg.groupid,hg.hostid from hosts_groups hg,hosts h where hg.hostid=h.hostid and h.status in (0,1) and h.flags<>2 order by hg.groupid]
    17051:20200309:113116.198 query [txnlev:0] [select maintenanceid,maintenance_type,active_since,active _till,tags_evaltype from maintenances]
    17051:20200309:113116.198 query [txnlev:0] [select maintenancetagid,maintenanceid,operator,tag,value from maintenance_tag]
    17051:20200309:113116.199 query [txnlev:0] [select t.timeperiodid,t.timeperiod_type,t.every,t.month,t .dayofweek,t.day,t.start_time,t.period,t.start_dat e,m.maintenanceid from maintenances_windows m,timeperiods t where t.timeperiodid=m.timeperiodid]
    17051:20200309:113116.202 query [txnlev:0] [select maintenanceid,groupid from maintenances_groups order by maintenanceid]
    17051:20200309:113116.202 query [txnlev:0] [select maintenanceid,hostid from maintenances_hosts order by maintenanceid]
    17051:20200309:113116.203 In DCsync_hosts()
    17051:20200309:113116.203 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
    17051:20200309:113116.203 ====== Fatal information: ======
    17051:20200309:113116.203 Program counter: 0x7f94fa480641
    17051:20200309:113116.203 === Registers: ===
    17051:20200309:113116.203 r8 = 23 = 35 = 35
    17051:20200309:113116.203 r9 = d8 = 216 = 216
    17051:20200309:113116.203 r10 = 0 = 0 = 0
    17051:20200309:113116.203 r11 = 7f94fa49e9d0 = 140277831035344 = 140277831035344
    17051:20200309:113116.203 r12 = 56078cbaa6b7 = 94590425802423 = 94590425802423
    17051:20200309:113116.203 r13 = 1 = 1 = 1
    17051:20200309:113116.203 r14 = 0 = 0 = 0
    17051:20200309:113116.203 r15 = 0 = 0 = 0
    17051:20200309:113116.204 rdi = 0 = 0 = 0
    17051:20200309:113116.204 rsi = fffffffffffffffc = 18446744073709551612 = -4
    17051:20200309:113116.204 rbp = 7ffe1a788190 = 140729342525840 = 140729342525840
    17051:20200309:113116.204 rbx = 1 = 1 = 1
    17051:20200309:113116.204 rdx = fffffffffffffffc = 18446744073709551612 = -4
    17051:20200309:113116.204 rax = 0 = 0 = 0
    17051:20200309:113116.204 rcx = 0 = 0 = 0
    17051:20200309:113116.204 rsp = 7ffe1a788178 = 140729342525816 = 140729342525816
    17051:20200309:113116.204 rip = 7f94fa480641 = 140277830911553 = 140277830911553
    17051:20200309:113116.204 efl = 10283 = 66179 = 66179
    17051:20200309:113116.204 csgsfs = 33 = 51 = 51
    17051:20200309:113116.204 err = 4 = 4 = 4
    17051:20200309:113116.204 trapno = e = 14 = 14
    17051:20200309:113116.204 oldmask = 0 = 0 = 0
    17051:20200309:113116.204 cr2 = 0 = 0 = 0
    17051:20200309:113116.204 === Backtrace: ===
    17051:20200309:113116.204 18: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x42) [0x56078cae5024]
    17051:20200309:113116.204 17: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x151) [0x56078cae52a2]
    17051:20200309:113116.205 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1a863a) [0x56078cae563a]
    17051:20200309:113116.205 15: /lib64/libpthread.so.0(+0xf5f0) [0x7f94fd49f5f0]
    17051:20200309:113116.205 14: /lib64/libc.so.6(+0x16f641) [0x7f94fa480641]
    17051:20200309:113116.205 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_default_string_hash_func+0x18) [0x56078cae6978]
    17051:20200309:113116.205 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x16d1ae) [0x56078caaa1ae]
    17051:20200309:113116.205 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_search+0x36) [0x56078caea5fc]
    17051:20200309:113116.205 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x16d209) [0x56078caaa209]
    17051:20200309:113116.205 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCstrpool_replace+0x55) [0x56078caaa346]
    17051:20200309:113116.205 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x16e689) [0x56078caab689]
    17051:20200309:113116.205 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x8a2) [0x56078cab5482]
    17051:20200309:113116.205 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x12b) [0x56078c98c0af]
    17051:20200309:113116.205 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x56078caf2aa7]
    17051:20200309:113116.205 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x9b1) [0x56078c97ed28]
    17051:20200309:113116.205 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x305) [0x56078cae488d]
    17051:20200309:113116.205 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x312) [0x56078c97e375]
    17051:20200309:113116.205 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f94fa333505]
    17051:20200309:113116.205 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x40409) [0x56078c97d409]
    17051:20200309:113116.205 === Memory map: ===
    17051:20200309:113116.205 56078c93d000-56078cc2b000 r-xp 00000000 fd:00 605 /usr/sbin/zabbix_server_mysql
    17051:20200309:113116.205 56078ce2a000-56078ce99000 r--p 002ed000 fd:00 605 /usr/sbin/zabbix_server_mysql
    17051:20200309:113116.205 56078ce99000-56078cea4000 rw-p 0035c000 fd:00 605 /usr/sbin/zabbix_server_mysql
    17051:20200309:113116.206 56078cea4000-56078ceae000 rw-p 00000000 00:00 0
    17051:20200309:113116.206 56078d07f000-56078d0a0000 rw-p 00000000 00:00 0 [heap]
    17051:20200309:113116.206 56078d0a0000-56078d0c1000 rw-p 00000000 00:00 0 [heap]
    17051:20200309:113116.206 56078d0c1000-56078d125000 rw-p 00000000 00:00 0 [heap]
    17051:20200309:113116.206 7f94aeb53000-7f94ceb53000 rw-s 00000000 00:04 5767176 /SYSV00000000 (deleted)
    17051:20200309:113116.206 7f94ceb53000-7f94deb53000 rw-s 00000000 00:04 5701638 /SYSV00000000 (deleted)
    17051:20200309:113116.206 7f94deb53000-7f94e2b53000 rw-s 00000000 00:04 5668869 /SYSV00000000 (deleted)
    17051:20200309:113116.206 7f94e2b53000-7f94e6b53000 rw-s 00000000 00:04 5636100 /SYSV00000000 (deleted)
    17051:20200309:113116.206 7f94e6b53000-7f94f6b53000 rw-s 00000000 00:04 5603331 /SYSV00000000 (deleted)
    17051:20200309:113116.206 7f94f6b53000-7f94f6b5f000 r-xp 00000000 fd:00 160780 /usr/lib64/libnss_files-2.17.so
    17051:20200309:113116.206 7f94f6b5f000-7f94f6d5e000 ---p 0000c000 fd:00 160780 /usr/lib64/libnss_files-2.17.so
    17051:20200309:113116.206 7f94f6d5e000-7f94f6d5f000 r--p 0000b000 fd:00 160780 /usr/lib64/libnss_files-2.17.so
    17051:20200309:113116.206 7f94f6d5f000-7f94f6d60000 rw-p 0000c000 fd:00 160780 /usr/lib64/libnss_files-2.17.so
    17051:20200309:113116.206 7f94f6d60000-7f94f6d66000 rw-p 00000000 00:00 0
    17051:20200309:113116.206 7f94f6d66000-7f94f6d68000 r-xp 00000000 fd:00 7093 /usr/lib64/libfreebl3.so
    17051:20200309:113116.206 7f94f6d68000-7f94f6f67000 ---p 00002000 fd:00 7093 /usr/lib64/libfreebl3.so
    17051:20200309:113116.206 7f94f6f67000-7f94f6f68000 r--p 00001000 fd:00 7093 /usr/lib64/libfreebl3.so
    17051:20200309:113116.206 7f94f6f68000-7f94f6f69000 rw-p 00002000 fd:00 7093 /usr/lib64/libfreebl3.so
    17051:20200309:113116.206 7f94f6f69000-7f94f6f8d000 r-xp 00000000 fd:00 42923 /usr/lib64/libselinux.so.1
    17051:20200309:113116.206 7f94f6f8d000-7f94f718c000 ---p 00024000 fd:00 42923 /usr/lib64/libselinux.so.1
    17051:20200309:113116.206 7f94f718c000-7f94f718d000 r--p 00023000 fd:00 42923 /usr/lib64/libselinux.so.1
    17051:20200309:113116.206 7f94f718d000-7f94f718e000 rw-p 00024000 fd:00 42923 /usr/lib64/libselinux.so.1
    17051:20200309:113116.206 7f94f718e000-7f94f7190000 rw-p 00000000 00:00 0
    17051:20200309:113116.206 7f94f7190000-7f94f7197000 r-xp 00000000 fd:00 170438 /usr/lib64/librt-2.17.so
    17051:20200309:113116.206 7f94f7197000-7f94f7396000 ---p 00007000 fd:00 170438 /usr/lib64/librt-2.17.so
    17051:20200309:113116.206 7f94f7396000-7f94f7397000 r--p 00006000 fd:00 170438 /usr/lib64/librt-2.17.so
    17051:20200309:113116.206 7f94f7397000-7f94f7398000 rw-p 00007000 fd:00 170438 /usr/lib64/librt-2.17.so
    17051:20200309:113116.206 7f94f7398000-7f94f73a0000 r-xp 00000000 fd:00 160760 /usr/lib64/libcrypt-2.17.so
    17051:20200309:113116.206 7f94f73a0000-7f94f759f000 ---p 00008000 fd:00 160760 /usr/lib64/libcrypt-2.17.so
    17051:20200309:113116.206 7f94f759f000-7f94f75a0000 r--p 00007000 fd:00 160760 /usr/lib64/libcrypt-2.17.so
    17051:20200309:113116.206 7f94f75a0000-7f94f75a1000 rw-p 00008000 fd:00 160760 /usr/lib64/libcrypt-2.17.so
    17051:20200309:113116.206 7f94f75a1000-7f94f75cf000 rw-p 00000000 00:00 0
    17051:20200309:113116.207 7f94f75cf000-7f94f75d2000 r-xp 00000000 fd:00 79656 /usr/lib64/libkeyutils.so.1.5
    17051:20200309:113116.207 7f94f75d2000-7f94f77d1000 ---p 00003000 fd:00 79656 /usr/lib64/libkeyutils.so.1.5
    17051:20200309:113116.207 7f94f77d1000-7f94f77d2000 r--p 00002000 fd:00 79656 /usr/lib64/libkeyutils.so.1.5
    17051:20200309:113116.207 7f94f77d2000-7f94f77d3000 rw-p 00003000 fd:00 79656 /usr/lib64/libkeyutils.so.1.5
    17051:20200309:113116.207 7f94f77d3000-7f94f77e1000 r-xp 00000000 fd:00 221699 /usr/lib64/libkrb5support.so.0.1
    17051:20200309:113116.207 7f94f77e1000-7f94f79e1000 ---p 0000e000 fd:00 221699 /usr/lib64/libkrb5support.so.0.1
    17051:20200309:113116.207 7f94f79e1000-7f94f79e2000 r--p 0000e000 fd:00 221699 /usr/lib64/libkrb5support.so.0.1
    17051:20200309:113116.207 7f94f79e2000-7f94f79e3000 rw-p 0000f000 fd:00 221699 /usr/lib64/libkrb5support.so.0.1
    17051:20200309:113116.207 7f94f79e3000-7f94f7a15000 r-xp 00000000 fd:00 55504 /usr/lib64/libidn.so.11.6.11
    17051:20200309:113116.207 7f94f7a15000-7f94f7c14000 ---p 00032000 fd:00 55504 /usr/lib64/libidn.so.11.6.11
    17051:20200309:113116.207 7f94f7c14000-7f94f7c15000 r--p 00031000 fd:00 55504 /usr/lib64/libidn.so.11.6.11
    17051:20200309:113116.207 7f94f7c15000-7f94f7c16000 rw-p 00032000 fd:00 55504 /usr/lib64/libidn.so.11.6.11
    17051:20200309:113116.207 7f94f7c16000-7f94f7c50000 r-xp 00000000 fd:00 31366 /usr/lib64/libnspr4.so
    17051:20200309:113116.207 7f94f7c50000-7f94f7e4f000 ---p 0003a000 fd:00 31366 /usr/lib64/libnspr4.so
    17051:20200309:113116.207 7f94f7e4f000-7f94f7e50000 r--p 00039000 fd:00 31366 /usr/lib64/libnspr4.so
    17051:20200309:113116.207 7f94f7e50000-7f94f7e52000 rw-p 0003a000 fd:00 31366 /usr/lib64/libnspr4.so
    17051:20200309:113116.207 7f94f7e52000-7f94f7e54000 rw-p 00000000 00:00 0
    17051:20200309:113116.207 7f94f7e54000-7f94f7e58000 r-xp 00000000 fd:00 32517 /usr/lib64/libplc4.so
    17051:20200309:113116.207 7f94f7e58000-7f94f8057000 ---p 00004000 fd:00 32517 /usr/lib64/libplc4.so
    17051:20200309:113116.207 7f94f8057000-7f94f8058000 r--p 00003000 fd:00 32517 /usr/lib64/libplc4.so
    17051:20200309:113116.207 7f94f8058000-7f94f8059000 rw-p 00004000 fd:00 32517 /usr/lib64/libplc4.so
    17051:20200309:113116.207 7f94f8059000-7f94f805c000 r-xp 00000000 fd:00 220947 /usr/lib64/libplds4.so
    17051:20200309:113116.207 7f94f805c000-7f94f825b000 ---p 00003000 fd:00 220947 /usr/lib64/libplds4.so
    17051:20200309:113116.207 7f94f825b000-7f94f825c000 r--p 00002000 fd:00 220947 /usr/lib64/libplds4.so
    17051:20200309:113116.207 7f94f825c000-7f94f825d000 rw-p 00003000 fd:00 220947 /usr/lib64/libplds4.so
    17051:20200309:113116.207 7f94f825d000-7f94f8286000 r-xp 00000000 fd:00 227575 /usr/lib64/libnssutil3.so
    17051:20200309:113116.207 7f94f8286000-7f94f8485000 ---p 00029000 fd:00 227575 /usr/lib64/libnssutil3.so
    17051:20200309:113116.207 7f94f8485000-7f94f848c000 r--p 00028000 fd:00 227575 /usr/lib64/libnssutil3.so
    17051:20200309:113116.208 7f94f848c000-7f94f848d000 rw-p 0002f000 fd:00 227575 /usr/lib64/libnssutil3.so
    17051:20200309:113116.208 7f94f848d000-7f94f85b3000 r-xp 00000000 fd:00 227579 /usr/lib64/libnss3.so
    17051:20200309:113116.208 7f94f85b3000-7f94f87b3000 ---p 00126000 fd:00 227579 /usr/lib64/libnss3.so
    17051:20200309:113116.208 7f94f87b3000-7f94f87b8000 r--p 00126000 fd:00 227579 /usr/lib64/libnss3.so
    17051:20200309:113116.208 7f94f87b8000-7f94f87ba000 rw-p 0012b000 fd:00 227579 /usr/lib64/libnss3.so
    17051:20200309:113116.208 7f94f87ba000-7f94f87bc000 rw-p 00000000 00:00 0
    17051:20200309:113116.208 7f94f87bc000-7f94f87e1000 r-xp 00000000 fd:00 227580 /usr/lib64/libsmime3.so
    17051:20200309:113116.208 7f94f87e1000-7f94f89e0000 ---p 00025000 fd:00 227580 /usr/lib64/libsmime3.so
    17051:20200309:113116.208 7f94f89e0000-7f94f89e3000 r--p 00024000 fd:00 227580 /usr/lib64/libsmime3.so
    17051:20200309:113116.208 7f94f89e3000-7f94f89e4000 rw-p 00027000 fd:00 227580 /usr/lib64/libsmime3.so
    17051:20200309:113116.208 7f94f89e4000-7f94f8a37000 r-xp 00000000 fd:00 7665 /usr/lib64/libssl3.so
    17051:20200309:113116.208 7f94f8a37000-7f94f8c37000 ---p 00053000 fd:00 7665 /usr/lib64/libssl3.so
    17051:20200309:113116.208 7f94f8c37000-7f94f8c3b000 r--p 00053000 fd:00 7665 /usr/lib64/libssl3.so
    17051:20200309:113116.208 7f94f8c3b000-7f94f8c3c000 rw-p 00057000 fd:00 7665 /usr/lib64/libssl3.so
    17051:20200309:113116.208 7f94f8c3c000-7f94f8c3d000 rw-p 00000000 00:00 0
    17051:20200309:113116.208 7f94f8c3d000-7f94f8c59000 r-xp 00000000 fd:00 89752 /usr/lib64/libsasl2.so.3.0.0
    17051:20200309:113116.208 7f94f8c59000-7f94f8e58000 ---p 0001c000 fd:00 89752 /usr/lib64/libsasl2.so.3.0.0
    17051:20200309:113116.208 7f94f8e58000-7f94f8e59000 r--p 0001b000 fd:00 89752 /usr/lib64/libsasl2.so.3.0.0
    17051:20200309:113116.208 7f94f8e59000-7f94f8e5a000 rw-p 0001c000 fd:00 89752 /usr/lib64/libsasl2.so.3.0.0
    17051:20200309:113116.208 7f94f8e5a000-7f94f8e61000 r-xp 00000000 fd:00 79661 /usr/lib64/libgdbm.so.4.0.0
    17051:20200309:113116.208 7f94f8e61000-7f94f9061000 ---p 00007000 fd:00 79661 /usr/lib64/libgdbm.so.4.0.0
    17051:20200309:113116.208 7f94f9061000-7f94f9062000 r--p 00007000 fd:00 79661 /usr/lib64/libgdbm.so.4.0.0
    17051:20200309:113116.208 7f94f9062000-7f94f9063000 rw-p 00008000 fd:00 79661 /usr/lib64/libgdbm.so.4.0.0
    17051:20200309:113116.209 7f94f9063000-7f94f906b000 r-xp 00000000 fd:00 116828 /usr/lib64/libOpenIPMIutils.so.0.0.1
    17051:20200309:113116.209 7f94f906b000-7f94f926b000 ---p 00008000 fd:00 116828 /usr/lib64/libOpenIPMIutils.so.0.0.1
    17051:20200309:113116.209 7f94f926b000-7f94f926c000 r--p 00008000 fd:00 116828 /usr/lib64/libOpenIPMIutils.so.0.0.1
    17051:20200309:113116.209 7f94f926c000-7f94f926d000 rw-p 00009000 fd:00 116828 /usr/lib64/libOpenIPMIutils.so.0.0.1
    17051:20200309:113116.209 7f94f926d000-7f94f9276000 r-xp 00000000 fd:00 28228 /usr/lib64/libltdl.so.7.3.0
    17051:20200309:113116.209 7f94f9276000-7f94f9475000 ---p 00009000 fd:00 28228 /usr/lib64/libltdl.so.7.3.0
    17051:20200309:113116.209 7f94f9475000-7f94f9476000 r--p 00008000 fd:00 28228 /usr/lib64/libltdl.so.7.3.0
    17051:20200309:113116.209 7f94f9476000-7f94f9477000 rw-p 00009000 fd:00 28228 /usr/lib64/libltdl.so.7.3.0
    17051:20200309:113116.209 7f94f9477000-7f94f949c000 r-xp 00000000 fd:00 7668 /usr/lib64/liblzma.so.5.2.2
    17051:20200309:113116.209 7f94f949c000-7f94f969b000 ---p 00025000 fd:00 7668 /usr/lib64/liblzma.so.5.2.2
    17051:20200309:113116.209 7f94f969b000-7f94f969c000 r--p 00024000 fd:00 7668 /usr/lib64/liblzma.so.5.2.2
    17051:20200309:113116.209 7f94f969c000-7f94f969d000 rw-p 00025000 fd:00 7668 /usr/lib64/liblzma.so.5.2.2
    17051:20200309:113116.209 7f94f969d000-7f94f96ce000 r-xp 00000000 fd:00 60883 /usr/lib64/libk5crypto.so.3.1
    17051:20200309:113116.209 7f94f96ce000-7f94f98cd000 ---p 00031000 fd:00 60883 /usr/lib64/libk5crypto.so.3.1
    17051:20200309:113116.209 7f94f98cd000-7f94f98cf000 r--p 00030000 fd:00 60883 /usr/lib64/libk5crypto.so.3.1
    17051:20200309:113116.209 7f94f98cf000-7f94f98d0000 rw-p 00032000 fd:00 60883 /usr/lib64/libk5crypto.so.3.1
    17051:20200309:113116.209 7f94f98d0000-7f94f98d3000 r-xp 00000000 fd:00 60876 /usr/lib64/libcom_err.so.2.1
    17051:20200309:113116.209 7f94f98d3000-7f94f9ad2000 ---p 00003000 fd:00 60876 /usr/lib64/libcom_err.so.2.1
    17051:20200309:113116.209 7f94f9ad2000-7f94f9ad3000 r--p 00002000 fd:00 60876 /usr/lib64/libcom_err.so.2.1
    17051:20200309:113116.209 7f94f9ad3000-7f94f9ad4000 rw-p 00003000 fd:00 60876 /usr/lib64/libcom_err.so.2.1
    17051:20200309:113116.209 7f94f9ad4000-7f94f9bad000 r-xp 00000000 fd:00 60889 /usr/lib64/libkrb5.so.3.3
    17051:20200309:113116.209 7f94f9bad000-7f94f9dac000 ---p 000d9000 fd:00 60889 /usr/lib64/libkrb5.so.3.3
    17051:20200309:113116.209 7f94f9dac000-7f94f9dba000 r--p 000d8000 fd:00 60889 /usr/lib64/libkrb5.so.3.3
    17051:20200309:113116.209 7f94f9dba000-7f94f9dbd000 rw-p 000e6000 fd:00 60889 /usr/lib64/libkrb5.so.3.3
    17051:20200309:113116.209 7f94f9dbd000-7f94f9e07000 r-xp 00000000 fd:00 220972 /usr/lib64/libgssapi_krb5.so.2.2
    17051:20200309:113116.209 7f94f9e07000-7f94fa007000 ---p 0004a000 fd:00 220972 /usr/lib64/libgssapi_krb5.so.2.2
    17051:20200309:113116.209 7f94fa007000-7f94fa008000 r--p 0004a000 fd:00 220972 /usr/lib64/libgssapi_krb5.so.2.2
    17051:20200309:113116.209 7f94fa008000-7f94fa00a000 rw-p 0004b000 fd:00 220972 /usr/lib64/libgssapi_krb5.so.2.2
    17051:20200309:113116.210 7f94fa00a000-7f94fa0f3000 r-xp 00000000 fd:00 61224 /usr/lib64/libstdc++.so.6.0.19
    17051:20200309:113116.210 7f94fa0f3000-7f94fa2f2000 ---p 000e9000 fd:00 61224 /usr/lib64/libstdc++.so.6.0.19
    17051:20200309:113116.210 7f94fa2f2000-7f94fa2fa000 r--p 000e8000 fd:00 61224 /usr/lib64/libstdc++.so.6.0.19
    17051:20200309:113116.210 7f94fa2fa000-7f94fa2fc000 rw-p 000f0000 fd:00 61224 /usr/lib64/libstdc++.so.6.0.19
    17051:20200309:113116.210 7f94fa2fc000-7f94fa311000 rw-p 00000000 00:00 0
    17051:20200309:113116.210 7f94fa311000-7f94fa4d4000 r-xp 00000000 fd:00 7100 /usr/lib64/libc-2.17.so
    17051:20200309:113116.210 7f94fa4d4000-7f94fa6d4000 ---p 001c3000 fd:00 7100 /usr/lib64/libc-2.17.so
    17051:20200309:113116.210 7f94fa6d4000-7f94fa6d8000 r--p 001c3000 fd:00 7100 /usr/lib64/libc-2.17.so
    17051:20200309:113116.210 7f94fa6d8000-7f94fa6da000 rw-p 001c7000 fd:00 7100 /usr/lib64/libc-2.17.so
    17051:20200309:113116.210 7f94fa6da000-7f94fa6df000 rw-p 00000000 00:00 0
    17051:20200309:113116.210 7f94fa6df000-7f94fa6f4000 r-xp 00000000 fd:00 107852 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
    17051:20200309:113116.210 7f94fa6f4000-7f94fa8f3000 ---p 00015000 fd:00 107852 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
    17051:20200309:113116.210 7f94fa8f3000-7f94fa8f4000 r--p 00014000 fd:00 107852 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
    17051:20200309:113116.210 7f94fa8f4000-7f94fa8f5000 rw-p 00015000 fd:00 107852 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
    17051:20200309:113116.210 7f94fa8f5000-7f94fa955000 r-xp 00000000 fd:00 268 /usr/lib64/libpcre.so.1.2.0
    17051:20200309:113116.210 7f94fa955000-7f94fab55000 ---p 00060000 fd:00 268 /usr/lib64/libpcre.so.1.2.0
    17051:20200309:113116.210 7f94fab55000-7f94fab56000 r--p 00060000 fd:00 268 /usr/lib64/libpcre.so.1.2.0
    17051:20200309:113116.210 7f94fab56000-7f94fab57000 rw-p 00061000 fd:00 268 /usr/lib64/libpcre.so.1.2.0
    17051:20200309:113116.210 7f94fab57000-7f94fab6d000 r-xp 00000000 fd:00 162897 /usr/lib64/libresolv-2.17.so
    17051:20200309:113116.210 7f94fab6d000-7f94fad6c000 ---p 00016000 fd:00 162897 /usr/lib64/libresolv-2.17.so
    17051:20200309:113116.210 7f94fad6c000-7f94fad6d000 r--p 00015000 fd:00 162897 /usr/lib64/libresolv-2.17.so
    17051:20200309:113116.210 7f94fad6d000-7f94fad6e000 rw-p 00016000 fd:00 162897 /usr/lib64/libresolv-2.17.so
    17051:20200309:113116.210 7f94fad6e000-7f94fad70000 rw-p 00000000 00:00 0
    17051:20200309:113116.210 7f94fad70000-7f94fadd6000 r-xp 00000000 fd:00 46973 /usr/lib64/libcurl.so.4.3.0
    17051:20200309:113116.210 7f94fadd6000-7f94fafd6000 ---p 00066000 fd:00 46973 /usr/lib64/libcurl.so.4.3.0
    17051:20200309:113116.210 7f94fafd6000-7f94fafd8000 r--p 00066000 fd:00 46973 /usr/lib64/libcurl.so.4.3.0
    17051:20200309:113116.210 7f94fafd8000-7f94fafd9000 rw-p 00068000 fd:00 46973 /usr/lib64/libcurl.so.4.3.0
    17051:20200309:113116.210 7f94fafd9000-7f94fafda000 rw-p 00000000 00:00 0
    17051:20200309:113116.210 7f94fafda000-7f94fafe8000 r-xp 00000000 fd:00 222282 /usr/lib64/liblber-2.4.so.2.10.7
    17051:20200309:113116.210 7f94fafe8000-7f94fb1e7000 ---p 0000e000 fd:00 222282 /usr/lib64/liblber-2.4.so.2.10.7
    17051:20200309:113116.210 7f94fb1e7000-7f94fb1e8000 r--p 0000d000 fd:00 222282 /usr/lib64/liblber-2.4.so.2.10.7
    17051:20200309:113116.210 7f94fb1e8000-7f94fb1e9000 rw-p 0000e000 fd:00 222282 /usr/lib64/liblber-2.4.so.2.10.7
    17051:20200309:113116.210 7f94fb1e9000-7f94fb23b000 r-xp 00000000 fd:00 281114 /usr/lib64/libldap-2.4.so.2.10.7
    17051:20200309:113116.210 7f94fb23b000-7f94fb43b000 ---p 00052000 fd:00 281114 /usr/lib64/libldap-2.4.so.2.10.7
    17051:20200309:113116.211 7f94fb43b000-7f94fb43d000 r--p 00052000 fd:00 281114 /usr/lib64/libldap-2.4.so.2.10.7
    17051:20200309:113116.211 7f94fb43d000-7f94fb43e000 rw-p 00054000 fd:00 281114 /usr/lib64/libldap-2.4.so.2.10.7
    17051:20200309:113116.211 7f94fb43e000-7f94fb484000 r-xp 00000000 fd:00 541901 /usr/lib64/libevent-2.0.so.5.1.9
    17051:20200309:113116.211 7f94fb484000-7f94fb683000 ---p 00046000 fd:00 541901 /usr/lib64/libevent-2.0.so.5.1.9
    17051:20200309:113116.211 7f94fb683000-7f94fb684000 r--p 00045000 fd:00 541901 /usr/lib64/libevent-2.0.so.5.1.9
    17051:20200309:113116.211 7f94fb684000-7f94fb685000 rw-p 00046000 fd:00 541901 /usr/lib64/libevent-2.0.so.5.1.9
    17051:20200309:113116.211 7f94fb685000-7f94fb686000 rw-p 00000000 00:00 0
    17051:20200309:113116.211 7f94fb686000-7f94fb68d000 r-xp 00000000 fd:00 116241 /usr/lib64/libOpenIPMIposix.so.0.0.1
    17051:20200309:113116.211 7f94fb68d000-7f94fb88c000 ---p 00007000 fd:00 116241 /usr/lib64/libOpenIPMIposix.so.0.0.1
    17051:20200309:113116.211 7f94fb88c000-7f94fb88d000 r--p 00006000 fd:00 116241 /usr/lib64/libOpenIPMIposix.so.0.0.1
    17051:20200309:113116.211 7f94fb88d000-7f94fb88e000 rw-p 00007000 fd:00 116241 /usr/lib64/libOpenIPMIposix.so.0.0.1
    17051:20200309:113116.211 7f94fb88e000-7f94fb97c000 r-xp 00000000 fd:00 116821 /usr/lib64/libOpenIPMI.so.0.0.5
    17051:20200309:113116.211 7f94fb97c000-7f94fbb7c000 ---p 000ee000 fd:00 116821 /usr/lib64/libOpenIPMI.so.0.0.5
    17051:20200309:113116.211 7f94fbb7c000-7f94fbb94000 r--p 000ee000 fd:00 116821 /usr/lib64/libOpenIPMI.so.0.0.5
    17051:20200309:113116.211 7f94fbb94000-7f94fbb99000 rw-p 00106000 fd:00 116821 /usr/lib64/libOpenIPMI.so.0.0.5
    17051:20200309:113116.211 7f94fbb99000-7f94fbb9d000 rw-p 00000000 00:00 0
    17051:20200309:113116.211 7f94fbb9d000-7f94fbbc8000 r-xp 00000000 fd:00 31628 /usr/lib64/libssh2.so.1.0.1
    17051:20200309:113116.211 7f94fbbc8000-7f94fbdc8000 ---p 0002b000 fd:00 31628 /usr/lib64/libssh2.so.1.0.1
    17051:20200309:113116.211 7f94fbdc8000-7f94fbdc9000 r--p 0002b000 fd:00 31628 /usr/lib64/libssh2.so.1.0.1
    17051:20200309:113116.211 7f94fbdc9000-7f94fbdca000 rw-p 0002c000 fd:00 31628 /usr/lib64/libssh2.so.1.0.1
    17051:20200309:113116.211 7f94fbdca000-7f94fbe92000 r-xp 00000000 fd:00 28209 /usr/lib64/libnetsnmp.so.31.0.2
    17051:20200309:113116.211 7f94fbe92000-7f94fc092000 ---p 000c8000 fd:00 28209 /usr/lib64/libnetsnmp.so.31.0.2
    17051:20200309:113116.211 7f94fc092000-7f94fc095000 r--p 000c8000 fd:00 28209 /usr/lib64/libnetsnmp.so.31.0.2
    17051:20200309:113116.211 7f94fc095000-7f94fc097000 rw-p 000cb000 fd:00 28209 /usr/lib64/libnetsnmp.so.31.0.2
    17051:20200309:113116.211 7f94fc097000-7f94fc0cd000 rw-p 00000000 00:00 0
    17051:20200309:113116.211 7f94fc0cd000-7f94fc12d000 r-xp 00000000 fd:00 28238 /usr/lib64/libodbc.so.2.0.0
    17051:20200309:113116.211 7f94fc12d000-7f94fc32c000 ---p 00060000 fd:00 28238 /usr/lib64/libodbc.so.2.0.0
    17051:20200309:113116.211 7f94fc32c000-7f94fc32d000 r--p 0005f000 fd:00 28238 /usr/lib64/libodbc.so.2.0.0
    17051:20200309:113116.211 7f94fc32d000-7f94fc334000 rw-p 00060000 fd:00 28238 /usr/lib64/libodbc.so.2.0.0
    17051:20200309:113116.211 7f94fc334000-7f94fc335000 rw-p 00000000 00:00 0
    17051:20200309:113116.211 7f94fc335000-7f94fc494000 r-xp 00000000 fd:00 43112 /usr/lib64/libxml2.so.2.9.1
    17051:20200309:113116.211 7f94fc494000-7f94fc693000 ---p 0015f000 fd:00 43112 /usr/lib64/libxml2.so.2.9.1
    17051:20200309:113116.211 7f94fc693000-7f94fc69b000 r--p 0015e000 fd:00 43112 /usr/lib64/libxml2.so.2.9.1
    17051:20200309:113116.211 7f94fc69b000-7f94fc69d000 rw-p 00166000 fd:00 43112 /usr/lib64/libxml2.so.2.9.1
    17051:20200309:113116.212 7f94fc69d000-7f94fc69f000 rw-p 00000000 00:00 0
    17051:20200309:113116.212 7f94fc69f000-7f94fc6a1000 r-xp 00000000 fd:00 160762 /usr/lib64/libdl-2.17.so
    17051:20200309:113116.212 7f94fc6a1000-7f94fc8a1000 ---p 00002000 fd:00 160762 /usr/lib64/libdl-2.17.so
    17051:20200309:113116.212 7f94fc8a1000-7f94fc8a2000 r--p 00002000 fd:00 160762 /usr/lib64/libdl-2.17.so
    17051:20200309:113116.212 7f94fc8a2000-7f94fc8a3000 rw-p 00003000 fd:00 160762 /usr/lib64/libdl-2.17.so
    17051:20200309:113116.212 7f94fc8a3000-7f94fcad9000 r-xp 00000000 fd:00 65399 /usr/lib64/libcrypto.so.1.0.2k
    17051:20200309:113116.212 7f94fcad9000-7f94fccd9000 ---p 00236000 fd:00 65399 /usr/lib64/libcrypto.so.1.0.2k
    17051:20200309:113116.212 7f94fccd9000-7f94fccf5000 r--p 00236000 fd:00 65399 /usr/lib64/libcrypto.so.1.0.2k
    17051:20200309:113116.212 7f94fccf5000-7f94fcd02000 rw-p 00252000 fd:00 65399 /usr/lib64/libcrypto.so.1.0.2k
    17051:20200309:113116.212 7f94fcd02000-7f94fcd06000 rw-p 00000000 00:00 0
    17051:20200309:113116.212 7f94fcd06000-7f94fcd6d000 r-xp 00000000 fd:00 105269 /usr/lib64/libssl.so.1.0.2k
    17051:20200309:113116.212 7f94fcd6d000-7f94fcf6d000 ---p 00067000 fd:00 105269 /usr/lib64/libssl.so.1.0.2k
    17051:20200309:113116.212 7f94fcf6d000-7f94fcf71000 r--p 00067000 fd:00 105269 /usr/lib64/libssl.so.1.0.2k
    17051:20200309:113116.212 7f94fcf71000-7f94fcf78000 rw-p 0006b000 fd:00 105269 /usr/lib64/libssl.so.1.0.2k
    17051:20200309:113116.212 7f94fcf78000-7f94fd079000 r-xp 00000000 fd:00 160764 /usr/lib64/libm-2.17.so
    17051:20200309:113116.212 7f94fd079000-7f94fd278000 ---p 00101000 fd:00 160764 /usr/lib64/libm-2.17.so
    17051:20200309:113116.212 7f94fd278000-7f94fd279000 r--p 00100000 fd:00 160764 /usr/lib64/libm-2.17.so
    17051:20200309:113116.212 7f94fd279000-7f94fd27a000 rw-p 00101000 fd:00 160764 /usr/lib64/libm-2.17.so
    17051:20200309:113116.212 7f94fd27a000-7f94fd28f000 r-xp 00000000 fd:00 42916 /usr/lib64/libz.so.1.2.7
    17051:20200309:113116.212 7f94fd28f000-7f94fd48e000 ---p 00015000 fd:00 42916 /usr/lib64/libz.so.1.2.7
    17051:20200309:113116.212 7f94fd48e000-7f94fd48f000 r--p 00014000 fd:00 42916 /usr/lib64/libz.so.1.2.7
    17051:20200309:113116.212 7f94fd48f000-7f94fd490000 rw-p 00015000 fd:00 42916 /usr/lib64/libz.so.1.2.7
    17051:20200309:113116.212 7f94fd490000-7f94fd4a7000 r-xp 00000000 fd:00 160795 /usr/lib64/libpthread-2.17.so
    17051:20200309:113116.212 7f94fd4a7000-7f94fd6a6000 ---p 00017000 fd:00 160795 /usr/lib64/libpthread-2.17.so
    17051:20200309:113116.212 7f94fd6a6000-7f94fd6a7000 r--p 00016000 fd:00 160795 /usr/lib64/libpthread-2.17.so
    17051:20200309:113116.212 7f94fd6a7000-7f94fd6a8000 rw-p 00017000 fd:00 160795 /usr/lib64/libpthread-2.17.so
    17051:20200309:113116.212 7f94fd6a8000-7f94fd6ac000 rw-p 00000000 00:00 0
    17051:20200309:113116.212 7f94fd6ac000-7f94fd9cc000 r-xp 00000000 fd:00 301 /usr/lib64/libmysqlclient.so.18.0.0
    17051:20200309:113116.213 7f94fd9cc000-7f94fdbcb000 ---p 00320000 fd:00 301 /usr/lib64/libmysqlclient.so.18.0.0
    17051:20200309:113116.213 7f94fdbcb000-7f94fdbd3000 r--p 0031f000 fd:00 301 /usr/lib64/libmysqlclient.so.18.0.0
    17051:20200309:113116.213 7f94fdbd3000-7f94fdc46000 rw-p 00327000 fd:00 301 /usr/lib64/libmysqlclient.so.18.0.0
    17051:20200309:113116.213 7f94fdc46000-7f94fdc50000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7f94fdc50000-7f94fdc72000 r-xp 00000000 fd:00 160754 /usr/lib64/ld-2.17.so
    17051:20200309:113116.213 7f94fde4f000-7f94fde68000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7f94fde69000-7f94fde6a000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7f94fde6a000-7f94fde6e000 rw-s 00000000 00:04 5734407 /SYSV00000000 (deleted)
    17051:20200309:113116.213 7f94fde6e000-7f94fde6f000 rw-s 00000000 00:04 5570562 /SYSV00000000 (deleted)
    17051:20200309:113116.213 7f94fde6f000-7f94fde70000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7f94fde70000-7f94fde71000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7f94fde71000-7f94fde72000 r--p 00021000 fd:00 160754 /usr/lib64/ld-2.17.so
    17051:20200309:113116.213 7f94fde72000-7f94fde73000 rw-p 00022000 fd:00 160754 /usr/lib64/ld-2.17.so
    17051:20200309:113116.213 7f94fde73000-7f94fde74000 rw-p 00000000 00:00 0
    17051:20200309:113116.213 7ffe1a76b000-7ffe1a78c000 rw-p 00000000 00:00 0 [stack]
    17051:20200309:113116.213 7ffe1a7a9000-7ffe1a7ab000 r-xp 00000000 00:00 0 [vdso]
    17051:20200309:113116.213 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
    17051:20200309:113116.213 ================================
    17051:20200309:113116.213 Please consider attaching a disassembly listing to your bug report.
    17051:20200309:113116.213 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    17050:20200309:113116.214 One child process died (PID:17051,exitcode/signal:1). Exiting ...
    17050:20200309:113116.214 zbx_on_exit() called
    17050:20200309:113116.214 In DBconnect() flag:1
    17050:20200309:113116.216 End of DBconnect():0
    17050:20200309:113116.216 In free_database_cache()
    17050:20200309:113116.216 In DCsync_all()
    17050:20200309:113116.216 In sync_history_cache_full() history_num:0
    17050:20200309:113116.216 End of sync_history_cache_full()
    17050:20200309:113116.216 In DCsync_trends() trends_num:0
    17050:20200309:113116.216 syncing trend data...
    17050:20200309:113116.216 query [txnlev:1] [begin;]
    17050:20200309:113116.216 query [txnlev:1] [commit;]
    17050:20200309:113116.216 syncing trend data done
    17050:20200309:113116.216 End of DCsync_trends()
    17050:20200309:113116.216 End of DCsync_all()
    17050:20200309:113116.216 End of free_database_cache()
    17050:20200309:113116.216 In free_configuration_cache()
    17050:20200309:113116.217 End of free_configuration_cache()
    17050:20200309:113116.217 In zbx_vc_destroy()
    17050:20200309:113116.217 End of zbx_vc_destroy()
    17050:20200309:113116.217 In free_selfmon_collector() collector:0x7f94fde6a000
    17050:20200309:113116.217 End of free_selfmon_collector()
    17050:20200309:113116.217 In zbx_unload_modules()
    17050:20200309:113116.217 End of zbx_unload_modules()
    17050:20200309:113116.217 Zabbix Server stopped. Zabbix 4.4.6 (revision 8cc702429d).
    Any ideas what I can do about this?
  • ebogaard
    • Nov 2019
    The crash seems to have a relationship with the added host. If I remove the new host from the DB, zabbix starts up again.
    As I changed the collations to utf8_bin some time ago and this is the first new host added since then, maybe something is wrong with the DB schema. I'm going to have a look at this lagter today and report back.
    • tim.mooney
      • Dec 2012
      • 1436
      As the messages say, you should report this to the Zabbix bugtracker. A segmentation violation (SEGV) is happening:
      Although it could be because of unexpected configuration, software shouldn't SEGV under normal conditions.
      • ebogaard
        • Nov 2019
        Okay, fixed it. I'm not sure if this is a 'regular' scenario, though: when mass-converting the varchar and text fields to collation utf8_bin, it seems I missed something and all fields were reset to "DEFAULT NULL", instead of "NOT NULL DEFAULT''". For example:
         CREATE TABLE `hostmacro` (
           `hostmacroid` bigint(20) UNSIGNED NOT NULL,
           `hostid` bigint(20) UNSIGNED NOT NULL,
        -  `macro` varchar(255) COLLATE utf8_bin DEFAULT NULL,
        -  `value` varchar(255) COLLATE utf8_bin DEFAULT NULL,
        -  `description` text COLLATE utf8_bin DEFAULT NULL
        +  `macro` varchar(255) COLLATE utf8_bin NOT NULL DEFAULT '',
        +  `value` varchar(255) COLLATE utf8_bin NOT NULL DEFAULT '',
        +  `description` text COLLATE utf8_bin NOT NULL
         ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_bin;
        Not sure this deserves a issue created.
