I have an Endian firewall, monitored by SNMP on Zabbix.
The eth1 (Gigabit) interface, was connected to a switch, to a Gigabit port.
But recently, it was switched to a 100mbps port on the same switch.
Now Zabbix constantly displays this message: "Interface eth1(): Ethernet has changed to lower speed than it was before"
and I want to adjust it so that you understand that now the speed is 100mbps.
Trigger: Interface eth1(): Ethernet has changed to lower speed than it was before
Problem expression:
{Endian Firewall:net.if.speed[ifHighSpeed.3].change()}<0 and {Endian Firewall:net.if.speed[ifHighSpeed.3].last()}>0 and ( {Endian Firewall:net.if.type[ifType.3].last()}=6 or {Endian Firewall:net.if.type[ifType.3].last()}=7 or {Endian Firewall:net.if.type[ifType.3].last()}=11 or
{Endian Firewall:net.if.type[ifType.3].last()}=62 or {Endian Firewall:net.if.type[ifType.3].last()}=69 or {Endian Firewall:net.if.type[ifType.3].last()}=117 ) and ({Endian Firewall:net.if.status[ifOperStatus.3].last()}<>2)
Recovery expression:
({Endian Firewall:net.if.speed[ifHighSpeed.3].change()}>0 and {Endian Firewall:net.if.speed[ifHighSpeed.3].prev()}>0) or ({Endian Firewall:net.if.status[ifOperStatus.3].last()}=2)
I didn't understand the logic and I don't know how to correct it.
Zabbix 4.0.0alpha7 // Endian Firewall Community release 3.2.5
Problem expression:
