failed: first network error, wait for 15 seconds
  • fsousa
    • Aug 2017
    • 99
    Hi everybody,
    I have the Zabbix 4.4.5 installed and some times I get a lot of false positives. When I get the false positives I have this on my logs:
    HTML Code:
      6024:20200313:153058.081 SNMP agent item "net.if.status[ifOperStatus.232]" on host "sw-isp-1.domain.net" failed: first network error, wait for 15 seconds
     5887:20200313:150425.014 Zabbix agent item "net.if.in[xenbr3]" on host "xen-qa-5.srv.domain" failed: first network error, wait for 15 seconds
      6024:20200313:150425.029 Zabbix agent item "system.boottime" on host "xen-qa-2.srv.domain" failed: first network error, wait for 15 seconds
      6048:20200313:150425.072 Zabbix agent item "vfs.fs.size[/var/log,pfree]" on host "xen-qa-1.srv.domain" failed: first network error, wait for 15 seconds
      5906:20200313:150425.101 Zabbix agent item "net.if.in[vif10.2]" on host "xen-qa-6.srv.domain" failed: first network error, wait for 15 seconds
      6052:20200313:150449.791 resuming Zabbix agent checks on host "xen-qa-1.srv.domain": connection restored
      6128:20200313:150449.791 resuming Zabbix agent checks on host "xen-qa-6.srv.domain": connection restored
      6073:20200313:150449.791 resuming Zabbix agent checks on host "xen-qa-2.srv.domain": connection restored
      6094:20200313:150449.797 resuming Zabbix agent checks on host "xen-qa-5.srv.domain": connection restored
      6009:20200313:150842.939 Zabbix agent item "net.if.out[eth2]" on host "xen-qa-1.srv.domain" failed: first network error, wait for 15 seconds
      5981:20200313:150842.946 Zabbix agent item "net.if.out[vif16.0]" on host "xen-qa-5.srv.domain" failed: first network error, wait for 15 seconds
      5928:20200313:150843.096 Zabbix agent item "net.if.out[vif26.3]" on host "xen-qa-4.srv.domain" failed: first network error, wait for 15 seconds
      6129:20200313:150859.177 resuming Zabbix agent checks on host "xen-qa-5.srv.domain": connection restored
      6077:20200313:150859.177 resuming Zabbix agent checks on host "xen-qa-1.srv.domain": connection restored
      6118:20200313:150859.188 resuming Zabbix agent checks on host "xen-qa-4.srv.domain": connection restored
      5927:20200313:151413.109 Zabbix agent item "net.if.in[vif1.3]" on host "xen-qa-4.srv.domain" failed: first network error, wait for 15 seconds
      5955:20200313:151413.138 Zabbix agent item "net.if.in[vif17.3]" on host "xen-qa-5.srv.domain" failed: first network error, wait for 15 seconds
      6013:20200313:151413.156 Zabbix agent item "vfs.fs.size[/var/log,used]" on host "xen-qa-6.srv.domain" failed: first network error, wait for 15 seconds
      5929:20200313:151413.163 Zabbix agent item "net.if.out[vif28.1]" on host "xen-qa-3.srv.domain" failed: first network error, wait for 15 seconds
      6126:20200313:151428.459 resuming Zabbix agent checks on host "xen-qa-6.srv.domain": connection restored
      6055:20200313:151428.462 resuming Zabbix agent checks on host "xen-qa-4.srv.domain": connection restored
      6126:20200313:151428.468 resuming Zabbix agent checks on host "xen-qa-5.srv.domain": connection restored
      6099:20200313:151428.470 resuming Zabbix agent checks on host "xen-qa-3.srv.domain": connection restored
    I don't understand what is happening ?
    If you need more detailed configation, let me know...
    Thank you.
  • Hamardaban
    • May 2019
    • 2714
    This most likely means that the server does not have time to get the requested value from the agent during the timeout period. For example due to the fact that the agent does not have time to calculate the size of files in the folder or something else. There may be problems in the network when transmitting data.... Also check the time synchronization between the agent and the server.
    See what's going on in the agent's logs. Use the options to increase the debugging level
    • bbrendon
      • Sep 2005
      • 873
      Did you figure this out? I have a similar issue. zabbix_get on the item key is fine but the zabbix server is freaking out. I'm getting the "failed: first network error, wait for 15 seconds" every 30 seconds or so to the same host. It's a 5.2.0 server but I'm not sure if the server version matters.
      EDIT: Found the issue. increase the server timeout (passive check) and not just the agent timeout.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • lptarik
        lptarik commented
        Hello Brendon, I didn't understand the increase the server timeout (passive check) part. Are you saying below config?
        ### Option: Timeout
        # Specifies how long we wait for agent, SNMP device or external check (in seconds).
        # Mandatory: no
        # Range: 1-30
        # Default:
        Timeout=30
