Host interface icons
  • knez
    • Dec 2019
    • 44
    Hello, everybody,
    Is there a possibility to add a new icon (for Modbus protocol) for the host interface... now there are four icons: Click image for larger version
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Currently, no. In 5.0 you will be able to integrate your own "modules" in the frontend:
    But that means creating additional pages, not editing existing ones. By the way, in 5.0 you will get "Monitoring -> Hosts":
    So, technically, in 5.0 you will be able to create your own "Monitoring -> Hosts" with additional indicators but you would have to implement the whole view from scratch.
    Alternatively you could create a simple view that displays hosts and custom indicators only, e. g. "Monitoring -> Modbus".
