Question about zabbix-agent with docker
  • t98907
    • Mar 2020
    Hi there,
    I installed zabbix-server on my host pc using zabbix/zabbix-appliance:ubuntu-4.4-latest.
    It looks to work fine.
    Then I installed zabbix-agent on the same host pc using zabbix/zabbix-agent:ubuntu-4.4-latest and failed to do that becase of failing to start zabbix-agent.
    Is there a way to monitor my host pc's health using zabbix-agent?
    Thank you.
  • t98907
    • Mar 2020
    /var/log/zabbix/zabbix-agentd.log is as follows:
     32514:20200326:163326.070 Starting Zabbix Agent [rpc-291]. Zabbix 4.4.7 (revision 77fb8c7ee0).
     32514:20200326:163326.071 **** Enabled features ****
     32514:20200326:163326.071 IPv6 support:          YES
     32514:20200326:163326.071 TLS support:           YES
     32514:20200326:163326.071 **************************
     32514:20200326:163326.071 using configuration file: /etc/zabbix/zabbix_agentd.conf
     32514:20200326:163326.071 listener failed: zbx_tcp_listen() fatal error: unable to serve on any address [[-]:10050]
     32514:20200326:163326.071 Zabbix Agent stopped. Zabbix 4.4.7 (revision 77fb8c7ee0).
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Looks like there is already a process listening on port 10050. Could you show the output of
      sudo netstat -lptn | grep 10050
      • t98907
        • Mar 2020
        Thank you. The problem is resolved.
