History table postgres DB
  • luissuez
    • Sep 2018
    • 11
    Hello all
    I see that my zabbix postgres database backup is about 920Gb... So I check the tables and I see this:
     SELECT
       relname as "Table",
       pg_size_pretty(pg_total_relation_size(relid)) As "Size",
       pg_size_pretty(pg_total_relation_size(relid) - pg_relation_size(relid)) as "External Size"
       FROM pg_catalog.pg_statio_user_tables ORDER BY pg_total_relation_size(relid) DESC;
             Table         |    Size    | External Size
     history_uint_20200127 | 11 GB      | 5695 MB
     history_uint_20200210 | 11 GB      | 5695 MB
     history_uint_20200203 | 11 GB      | 5695 MB
     history_uint_20200120 | 10 GB      | 5686 MB
    So, my question is..Can I just remove this table from the database safely ?
    If not, the way I have is to EXCLUDE this tables from my BARMAN backup script?
    Let me know
    Many thanks
  • Hamardaban
    • May 2019
    • 2714
    Making a conclusion by the table name, you may have partitioning enabled. If this is exactly the case (make sure to check), then these tables are children and can be deleted by the «drop table history_uint_blablabla» expression .
    • luissuez
      • Sep 2018
      • 11
      Hello Hamardaban
      yes, seem to be a partitionned table:
      SELECT table_name
      FROM information_schema.tables
      WHERE table_schema = 'public'
      ORDER BY table_name;
       history
       history_20180319
       history_20180326
      Triggers:
          history_t01 BEFORE INSERT ON history FOR EACH ROW EXECUTE PROCEDURE generic_partition_tp01()
      Child tables: history_20180319,
                    history_20180326,
                    history_20180402,
                    history_20180409,
                    history_20180416,
                    history_20180423,
                    history_20180430,
                    history_20180507,
      So... I can just drop them? Ok I'll try tomorrow
      Many thanks !
      • Hamardaban
        Hamardaban commented
        yes you can.
    • luissuez
      • Sep 2018
      • 11
      Hello Hamardaban
      well, this is what happens: I drop using this command:
       drop table history_uint_20190923;
      And just after droping, zabbix start to send a lot of alarm mails... All the triggers I receive 350 mails in one minute. So I restart zabbix server, the emails stops and ... the partitions have been created again !!
      and the DB size is =
      zabbix=# SELECT pg_size_pretty( pg_database_size('zabbix') );
       pg_size_pretty
       985 GB
      Do you ever seen this before?
      • Hamardaban
        • May 2019
        • 2714
        I've never seen anything like it! My system uses partitioning and nothing like this has ever happened when deleting child tables
        • luissuez
          • Sep 2018
          • 11
          Hello
          mmmm yes, I can imamgine.
          Just tell me, does this triggers are zabbix default trigger ? I'm pretty sure this is local code, and as I can see, this trigger create partitions automatically, so when you drop one or truncate one, this trigger fill it again...
          • Hamardaban
            • May 2019
            • 2714
            You can view the entire db schema in the server distribution file schema.sql. There are no specified triggers in it. You need to look at the text of triggers to understand what they do. But in any case, the trigger itself should not generate data! Perhaps you have set up some kind of data replication or applied some solution to ensure data backup / recovery?
