Curl request returns empty value
  • lbjensen
    • Apr 2013
    • 16
    Hi
    I have a weblogic REST call
    sudo -u zabbix /bin/curl -sk --user "userassword" -H "Accept: application/json" http://<IP>:7001/management/tenant-monitoring/clusters/cluster
    Returns from CLI:
    {"body":{"item":{"name":"kobra-cluster","servers":[{"name":"wls-01-01","state":"RUNNING","health":"HEALTH_OK","clus te rMaster":false,"resendRequestsCount":0,"fragmentsS entCount":121940,"fragmentsReceivedCount":0}]}},"messages":[]}
    Which is very good
    the item is configured as a userparameter
    UserParameter=weblogic.json[*],/bin/curl -sk --user "userassword" -H "Accept: application/json" $1
    From the Zabbix item i just get an empty value returned:
    76766:20200320:144110.660 for key [weblogic.json[http://<IP>:7001/management...obra-cluster]] received value []
    Frontend
    Macro {$CLUSTER}
    http://<IP>:7001/management/tenant-monitoring/clusters/kobra-cluster
    the latest data, is of course empty
    What could be the reason for the empty value
    Cheers
    Lars
  • lbjensen
    • Apr 2013
    • 16
    SOLUTION
    SElinux was the reason for the script not working
    The output is fine now
