Zabbix queue
  • SixArt
    • Jul 2015
    • 22
    Zabbix queue
    In Zabbix Server Health Screen I see the attach graph.
    I want to ask what is the value "Zabbix Queue"?
    Regards,
    Dario
  • mfortes
    • Oct 2019
    • 418
    Edit your dashboard page and check your Data set...
    Queue graphic:
    Michael R. Fortes
    Linkedin: Mike Fortes
    Medium: mromeiro-f
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Zabbix queue is the number of checks that are late and the values for which should have been already received. In other words, the bigger Zabbix queue - the worse. In your case the queue is growing, which is a bad indicator and you are already on 300K values that are late. This means there is a performance issue somewhere, either Zabbix server or Zabbix proxy or Zabbix agent etc. Go to "Administration -> Queue" to see what kind of checks are mostly in the queue, this should give you a better picture on where the problem might be.
      More info: https://www.zabbix.com/documentation...ig/items/queue
