Multiple actions firing on trigger.
  • kjetil_maland
    • Sep 2014
    • 11
    We have tried to make separate actions depending on application name.
    All items monitoring services has application name containing _SERVICES at the end.
    So we then have one action checking --> application name like _SERVICES
    And one that has application name not like _SERVICES.
    However both are firing when trigger goes into Problem state.
    Any tips to what might be wrong here ?
    Example:
    Action1
    Maintenance status not in maintenance
    Application not like _SERVICES
    Application not like _API_
    Application not like Filesystems
    Trigger value = PROBLEM
    Action2
    Application = Filesystems
    In my head Action1 should not fire when trigger related to an item where application contains Filesystems.
    It does however fire both actions. 0_o
  • BDiE8VNy
    • Apr 2010
    • 680
    Which calculation type is selected for the action conditions?
    • kjetil_maland
      • Sep 2014
      • 11
      Action 1
      A and (B or C or D) and E
      A Maintenance status not in maintenance
      B Application not like _SERVICES
      C Application not like _API_
      D Application not like Filesystems
      E Trigger value = PROBLEM
      Action 2
      A and B and C
      B Application = Filesystems
      C Trigger value = PROBLEM
      It seems to me there is a bug here.. that the 'Not Like' is treated as 'Like' instead.?
      • BDiE8VNy
        • Apr 2010
        • 680
        No, this means:
        A and ( "not like _SERVICES" or "not like _API_" or "not like Filesystems" ) and E
        So fires when one of these substrings is not found in the application name.
        Or in other words, 'Filesystems' is not like '%_API_%' and is also not like '%_SERVICES%'.
        • kjetil_maland
          • Sep 2014
          • 11
          DOH!
          If it mathces any of the "Not like"s the enitre () is true.
          And since i dont trust my brain at this stage..
          So A & (B&C&D) & E should be correct... right? 0_o
          • aib
            • Jan 2014
            • 1615
            looks more like:
            A & (B|C|D) & E
            Sincerely yours,
            Aleksey
            • jackie
              • Jan 2016
              • 37
              I'm running into this same type of issue, with "Trigger name not like". Isn't the correct configuration:
              A & (B&C&D) & E
              Seems like (B|C|D) would always be true??
              Also, are the () necessary? I tried A&B&C&D&E in our setup; and it didn't seem to work properly.
              Thanks for any clarification.
